Reinforcing frame
Old Feb 21, 2007 | 01:01 PM
cmerrick's Avatar
cmerrick
Default Reinforcing frame
Recently I picked up a nice 74 frame for a build up. It will see occasional road racing and be somewhere in the vacinity of 500HP. What areas of the frame should be reinforced or gussetted.
Old Feb 21, 2007 | 01:22 PM
Godfathers Ghost's Avatar
Godfathers Ghost
The ft control arm/shock towers. You can get or fab a spreader bar to tie them together. Make sure the trans crossmember is very secure, the atachments are prone to rust and will loosen up. Add rear end crossmember reinforcements available from VB&P and others, they're thick aluminum disks that attach were the c.m. bushings are. Add a poly bushing for the front rearend mount to go with them. These are simple inexpensive ways to help, but there are many other more elaberate things that can be done. Any triangulation, gussets in areas like the rear kick-up and crossmembers, and of course a rollcage will work wonders for ridgidity.
Old Feb 21, 2007 | 01:36 PM
willem wallace's Avatar
willem wallace
Default Frame
Hey Merrick,
I am also from MA., and also have a 1971 roadster, small world! Check this site out for some of your modifications. Be sure to follow all the way through on the frame section, as a couple of the gussets he installs arte totally wrong, but the others look like they will help with frame flex. www.corvette-restoration.com I am in the middle of a frame off on my car, looking for parts sources/ as it is a basketcase with lots missing. Do you have any parts for sale?
Michael
Old Feb 21, 2007 | 02:08 PM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by willem wallace
as a couple of the gussets he installs arte totally wrong, Michael
How can a gusset be totally wrong unless it runs into something??? I would like to see a picture of a wrong gusset.
I have posted alot on gusseting the frame. Maybe do a search.
These are a few links to some of my posts
http://www.digitalcorvettes.com/foru...ad.php?t=68803
http://www.digitalcorvettes.com/foru...ad.php?t=67187
http://www.digitalcorvettes.com/foru...ad.php?t=67264
http://www.digitalcorvettes.com/foru...ad.php?t=66368
http://www.digitalcorvettes.com/foru...ad.php?t=66095
Old Feb 21, 2007 | 02:15 PM
Godfathers Ghost
Only if its in a spot that strucurely does not need it, then its just adding weight. But you gotta be really clueless to be that wrong.
Old Feb 21, 2007 | 02:21 PM
norvalwilhelm
A good spot for a gusset is on the outside of the frame rail at the steering box. That hole should be plated over as well as re inforcing the frame at that location.
I also plate around the bend.
Old Feb 21, 2007 | 02:32 PM
TimAT's Avatar
TimAT
All the things that everyone else has mentioned, AND reweld the whole frame- go to full length welds on the rails. The factory just skip welded them. The old Chevy performance book pointed out the area around the steering box too.
Old Feb 21, 2007 | 02:40 PM
willem wallace
Default How?
Check out the info before you start running your mouth!
Old Feb 21, 2007 | 03:28 PM
V-Twin's Avatar
V-Twin
Can you please point out which ones are wrong? From reading here the gussets are not only for frame flex but also for reinforcing some areas that could use the extra strength.
Old Feb 21, 2007 | 04:45 PM
cmerrick's Avatar
cmerrick
Thanks for the info and links. I'll go through them tonight once I get home.
Old Feb 21, 2007 | 05:45 PM
redvetracr's Avatar
redvetracr
as TimAt pointed out...get an older copy of the Chevy Power book just make sure it has the Corvette chassis section...you can ususlly find one on ebay.
...redvetracr
Old Feb 21, 2007 | 06:36 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Hey Merrick,
Michael
Wow you couldn't be more off
Old Feb 21, 2007 | 07:36 PM
norvalwilhelm
Are you talking to me???
Old Feb 21, 2007 | 07:44 PM
norvalwilhelm
He put one under the steering box and when the box is installed it will hit this gusset. that comes under the heading of putting it in a place where it runs into something.
Old Feb 21, 2007 | 08:48 PM
68 NJConv 454's Avatar
68 NJConv 454
It also looked like his mech fuel pump would have hit one of the gussets so he grinded a little indent to it.
To Reinforcing frame
