Sparkplug...
Old Feb 21, 2007 | 05:48 PM
JustForFun's Avatar
JustForFun
Default Sparkplug...
My 72 has r44t plugs in it, but seem to fuel foul quite easily. A guy today told me to run r44ts and it would help because of the extended length....
comments? is that a better plug to run?
Old Feb 21, 2007 | 06:13 PM
TimAT's Avatar
TimAT
I don't know about better, but the extended tip IS more resistant to fouling. You may be jetted a little fat too. Or you could go to R45TS plugs. 1 step hotter.
Are the plugs coming out black? Or are you getting a miss? What does the exhaust smell like?
Old Feb 21, 2007 | 06:32 PM
JustForFun's Avatar
JustForFun
plugs are coming out very black, burns very rich...and is missing
Old Feb 21, 2007 | 06:52 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I think you should re-jet your carb, Installing hotter plugs is not the answer
Old Feb 21, 2007 | 11:03 PM
JustForFun's Avatar
JustForFun
not installing hotter plugs....asking about longer reach. same heat range
Old Feb 21, 2007 | 11:09 PM
TimAT's Avatar
TimAT
The extended tip is NOT longer reach. Longer reach would be the distance from the seat (where it tightens on the cyl head), to the END of the threads. Extended tip is exactly that. The tip (center electrode) is sticking out into the chamber a little more. Nothing wrong with that at all.
And if they're coming out black and sooty, that's a sign of too much fuel. Why is it so rich? Carb float? Jets too big? Let us know..
Old Feb 22, 2007 | 07:13 AM
1970 stingray's Avatar
1970 stingray
plugs arent the problem . your carb needs attention . whatever plug you put in there is going to do the same thing the plugs your using now are .
Old Feb 22, 2007 | 07:34 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If you run your car on just short trips, this will foul out any plug as the choke will be on most of the time. If perhaps this is the case, be sure to run the car for a half hour or more after start.
To Sparkplug...
