81 Dash Light Question
Old Feb 21, 2007 | 07:47 PM
TO_Vette's Avatar
TO_Vette
Default 81 Dash Light Question
Just had a new radio installed in my car 81. Noticed that the light in the image of a battery on the dash is on. At first, I thought it was that the battery needed to be charged because while installing the radio they left the car on for sometime. I drove the car home almost 15 miles and the light is still on.
What does this light mean?
Old Feb 21, 2007 | 07:51 PM
Big2Bird's Avatar
Big2Bird
It means there is a difference between the alternator output, and the battery voltage. They did something. Take it back.
Old Feb 21, 2007 | 08:00 PM
TO_Vette's Avatar
TO_Vette
What might cause this?
Old Feb 21, 2007 | 08:05 PM
Big2Bird's Avatar
Big2Bird
If the light was out when you went down there, and it is on now. I can only assume at this point.
They hooked the amp up to the alt, and did not tighten the connection.
They unplugged/disturbed the field coil connection plug.
They f____d your wiring up.(My vote)
If they ran the battery down, the light would go off as soon as the alt put out more than the battery.
Old Feb 21, 2007 | 08:36 PM
TO_Vette's Avatar
TO_Vette
I just took it for a 10 mile ride and the alt gauge stayed where it always is about 13 volts yet the light stayed on.
I called them but they are adamant that they just put in a radio and could not have caused any thing like that.
Guess I need to go down there and talk to them personally.
Old Feb 21, 2007 | 11:24 PM
TimAT's Avatar
TimAT
It's possible that a diode in your alternator died too. Stuff happend. If you have a gauge and it's at 13, and the light is on too, I'd vote for a diode.
Old Feb 22, 2007 | 12:04 AM
Big2Bird's Avatar
Big2Bird
It is possible. They could have ran a new wire from the alt output to the new amp, and shorted the post to ground.
One thing almost for sure.
It worked before, and now it does not.
Old Feb 22, 2007 | 10:48 AM
TO_Vette's Avatar
TO_Vette
No amp was installed and they say the installed the radio right into the existing wireing.
Old Feb 22, 2007 | 12:47 PM
ewjxn's Avatar
ewjxn
Default Check the Circuit Board
Check the contacts in the circuit board. They seperate from the plastic membrane very easily. It is possible that the bat. light contact has seperated and is now in contact with another +12 volt contact. Every time I take the center cluster out I check those contacts. A little super glue will reattach the contact to the plastic. Just make sure the glue is used carefully. Eric
Old Feb 22, 2007 | 08:49 PM
Big2Bird's Avatar
Big2Bird
Take car to audio shop.
Car fine.
Pick up car.
Car not fine.
Car not fine=audio shop no good.
Old Feb 22, 2007 | 08:57 PM
TO_Vette's Avatar
TO_Vette
Default Battery
Just had the battery diagnosed as bad.
Old Feb 22, 2007 | 10:07 PM
Big2Bird's Avatar
Big2Bird
That would mean the light is operating correctly.
To 81 Dash Light Question
