One man brake bleeder?
Old Feb 25, 2007 | 12:23 AM
noonie's Avatar
noonie
Originally Posted by norvalwilhelm
I pressurzie the master cylinder then bleed on front and one rear brake before refilling the master resovior. I set the shop regulater at a few pounds and connect it to a modified cover that is held to the master cylinder with the stock wire clips. Works great.......
You can buy a cheap replacement lid or use one from an old master to adapt for this.
