1976 fuel tank
Old Feb 25, 2007 | 10:26 AM
brookman's Avatar
brookman
Default 1976 fuel tank
Is there a sock on the pickup on a 76?
Old Feb 25, 2007 | 11:32 AM
Durango_Boy's Avatar
Durango_Boy
Should be, yes, if I'm not mistaken.
Old Feb 25, 2007 | 12:58 PM
Duke94's Avatar
Duke94
Yes. My 71' and 78' have it. Doc Rebuild catalog shows 63-82 use the same "strainer" on the tank pickup.
Old Feb 25, 2007 | 02:49 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
My '76 has the sock.
Old Feb 25, 2007 | 07:48 PM
brookman's Avatar
brookman
I see small particles in the glass fuel filter I installed - but I noticed when my son got home last night the electric pump was having problems getting fuel to it. The car sat for many years so there is probably gunk in the sock
Old Feb 25, 2007 | 08:23 PM
BKbroiler's Avatar
BKbroiler
If you decide to drop the tank for an inspection, keep us posted. I'm planning on doing the same thing on my 77.
Old Feb 25, 2007 | 10:46 PM
Steve COSD's Avatar
Steve COSD
Yes. I got one from the dealer for my 75.
Steve
Old Feb 26, 2007 | 09:25 AM
Durango_Boy
When and if you drop the tank, and check to make sure the bladder is still in place and that it hasn't sagged. Corrosion can set in and rust flakes can start accumulating on the sock.
Old Feb 26, 2007 | 10:00 AM
brookman's Avatar
brookman
So - the tank has a bladder? What happens? Does the bladder become detached from the top of the tank?
Old Feb 26, 2007 | 10:10 AM
Durango_Boy
Basically yes. More than likely it's still in place. It's just something to be aware of and to check when you pull the tank down to clean or replace the sock.
To 1976 fuel tank
