Engine revs when making hard right turn
Old Feb 25, 2007 | 11:10 AM
75coupered's Avatar
75coupered
Default Engine revs when making hard right turn
As of late, I've noticed an odd occurance, seems that the engine likes to rev up a bit, about 200 rpm or so when making a hard right turn, not on lefts, just rights.
I have a relatively stock 350 with the Edelbrock 1406 carb which is fed on the right side. Could this surge in fuel be caused by the right side carb float? or simply tipping in more fuel due to the force and angle of the turn?
Any ideas, I had not noticed the problem before, but then again the carb was out of whack and I've been playing with rods and springs to dial it in. Now she runs better but has this issue.
Thanks in advance,
Bill
Old Feb 25, 2007 | 03:45 PM
jim2527's Avatar
jim2527
Body flex causing 'pull' on the throttle cable?
Old Feb 25, 2007 | 05:20 PM
tfi racing's Avatar
tfi racing
Maybe a separated motor mount?
Old Feb 25, 2007 | 05:24 PM
MIKER's Avatar
MIKER
Check the transmission fluid level. Low fluid level could starve the transmission pump during hard cornering.
Old Feb 25, 2007 | 05:29 PM
Big2Bird's Avatar
Big2Bird
Thanks in advance,
Bill
Sounds like a float level issue to me.(IMHO)
Old Feb 25, 2007 | 07:03 PM
75coupered's Avatar
75coupered
Thanks guys,
I don't think the body is flexing much, she's very tight and all of the mount bushings are good.
Il'll double check the motor mount to eliminate this
The car's a 4-speed, but it does have power steering so I'll check the control box and pump.
I'll have to also dive into the carb, if this is a common float condition, I'd like to hear more about what others have found
Thanks,
Kid Vette's Avatar
Kid Vette
Old Feb 25, 2007 | 10:31 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Do you brace yourself during hard right turns with your right foot
Old Feb 26, 2007 | 07:28 PM
75coupered's Avatar
75coupered
Default you guys are great
Thanks to all for their tips.
Sure enough on closer inspection of the motor mounts, the right side mount is split. One of those little things that gets missed. Just curious as how this affects the engine, is it literally loose enough to tip the engine/carb and introduce more fuel?
Thanks again,
Bill
Old Feb 26, 2007 | 07:31 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Its like someone said above, the motor is moving when you turn right and pulling on the cable just enough to rev the motor. New motor mounts will fix it right up.
Old Feb 26, 2007 | 07:41 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I'd bet on it.
Old Feb 26, 2007 | 07:49 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
Originally Posted by Kid Vette
iagree:
Old Feb 26, 2007 | 07:52 PM
dgruenke's Avatar
dgruenke
Good call guys. I was thinking transmission fluid the whole way until he said he had a Manual. I've never even heard of the motor mount causing the rev. It makes sense though if it is pulling the throttle.
Old Feb 26, 2007 | 08:32 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
interesting..
only way i ever discovered a busted motor mount was by scraping the shet out of the fan shroud...
Old Feb 26, 2007 | 08:57 PM
Restorod '79's Avatar
Restorod '79
Good fix! I discovered my right mount broken when the air cleaner, sticking through the hood, kept getting caved in on one side.
To Engine revs when making hard right turn
