Steering Problems
Old Feb 25, 2007 | 08:10 PM
Berserker78's Avatar
Berserker78
Default Steering Problems
Last summer, my steering system was pretty much shot. The ram leaked like a sieve and the valve had too much wear in it to rebuild, so I replaced both of them and all the hoses with a rebuilt kit from Volunteer Vette Products.
I cannot seem to get it adjusted right though. Ever since the replacement, it has been much harder to turn the wheel and there is a dead zone of about 3-5 degrees from one side to the other.
Any suggestions on what might be the problem? I top off the fluid on a fairly regular basis. It doesn't seem to be leaking, so I am not sure if it is actually leaking or if it just isn't finished bleeding yet.
Jason
Old Feb 25, 2007 | 09:49 PM
wombvette's Avatar
wombvette
Some of these rebuilt components might not be good. Common problems of hard steering are a bad pump or ram. But, it also could be the valve. When you turn it all the way to lock and force it further, do you hear the pump growl or the engine RPM drop?
Old Feb 27, 2007 | 11:59 AM
Berserker78
Finally got to check it last night. Yes, when it gets to the extreme sides it does start to whine.
Jason
Old Feb 27, 2007 | 02:17 PM
wombvette's Avatar
wombvette
That is not a conclusive test, but it indicates that the pump is OK.
Old Feb 27, 2007 | 02:57 PM
Jim Shea's Avatar
Jim Shea
Have you tried balancing the valve? If you haven't, I can supply information on the procedure. That might be the whole problem.
Jim
Old Feb 27, 2007 | 04:42 PM
Berserker78
I thought I balanced it originally, but maybe I messed it up.
If the valve is unbalanced, wouldn't that result in it turning easier one way than the other?
I would appreciate info on the proper way to balance it, I would try doing again.
Old Feb 27, 2007 | 05:20 PM
Jim Shea's Avatar
Jim Shea
Here is a link to my paper on balancing the control valve. It also has two built in links to two scans at the www.corvettefaq.com websight.
http://jimshea.corvettefaq.com/wp-co...ance18oc06.doc
Jim
Old Feb 27, 2007 | 10:23 PM
Berserker78
Thanks a lot!
To Steering Problems
