350 Rocker Arm Adjustment
Old Feb 25, 2007 | 09:38 PM
dinodon51's Avatar
dinodon51
Default 350 Rocker Arm Adjustment
This is a minor point, but I just put some Crane 1.52 magnum roller rockers on my engine. One of my books says one full turn (Factory) after the pushrod meets resistance and the other 3/4 turn (Haynes). Which is recommended or is there enough give in the hydraulic lifter design that it doesn't make any difference?
Old Feb 26, 2007 | 09:59 AM
kevinator80's Avatar
kevinator80
According to Lars' paper the full turn factory spec. is the equivalent of a built in rev limiter. He suggests 1/2 turn for a performance application.
Old Feb 26, 2007 | 10:10 AM
panchop's Avatar
panchop
I ran a quarter turn with pro magnums on my RPM camed 327 with no bad side effects.
Old Feb 26, 2007 | 11:56 PM
dinodon51's Avatar
dinodon51
Kevinator:
What is "Lar's Paper?"
Old Feb 27, 2007 | 01:45 AM
1970 stingray's Avatar
1970 stingray
I will tell ya i was always a little gunshy about going down a full turn on the valves . I always went from zero lash , and took them down 1 qtr. turn .
To 350 Rocker Arm Adjustment
