Rusty Bore - What to do? - Dial up beware
I posted earlier that I bought a 73 with a bad engine. i picked up a replacement engine fairly cheep with some pretty good components and credentials. It's a 70 350/300. It had been sitting for a while but turned over and was (at least recently) stored indoors. I thought it was a good risk.
I took it apart this weekend to see what's what. it's raining here so time for indoor work. Here's what i found.
Before you say anything, these are "after" pictures.
I've been cleaning this cylinder for about an hour. Although a few of the bores show some water signs, this one is by far the worst. You can just barely see in the second picture that there is a rust ridge.
Most of this looks like it'll come off with aggressive cleaning. I'm using paper towels and transmission fluid on most of it and steel wool on the rust ridge.
Question is, what next? The intent of this engine was to tide me over until next winter by which time my new motor would be ready. I really don't want to sink a ton of money into this one, but i also don't want it to billow smoke, spit fire and blow up either.
A) Should I just clean it well and hope for the best?
B) Should I pull it apart and replace the rings and bearings? If B then would a cross hatching be in order?
C) Should I break down and have it bored?
The engine looks to have been bored very recently. There is no ridge whatsoever and only minimal carbon on the piston crowns. Nice, tight seal too. The oil that I poured into each bore yesterday is still sitting there.
While I have your attention, two additional and less important questions.
As you can see from the first pic, the engine builder loved blue Permatex. How do I get this off? Is a razor blade scraper a bad idea on the block on a mating surface? I was also thinking of using Goof Off, but it's on REALLY thick.
Second, can anone identify the piston? I assume that it is aftermarket because of the directional notch, but certainly don't know.
You certainly need to take the lower end apart for inspection and see what type of water damage you have down below.
How bad is the pitting in the cyl bores? Can you use a flex-hone on the bores and remove the rust?
Seems like a lot of work for an engine that is just going to see less than 12 mo of service. Wouldn't you rather take the cash and upgrade something else on the car?
Just my thoughts.
Bob
Just my thoughts.
Bob
Those pits are too deep for honing. I think it's more trouble than it's worth for 1 season.
Do you really think you can stick to this thought?? Most people don't. Next will be new pistons etc.
That is a minimum and yes hatch the bores
Your going to break your original intent. You know the part about the money!
I see a pretty shiny wall.
If you can't see the original crosshatch, you have wear and thus you have a ridge. If a new top ring hits even a small ridge the first few times the piston comes up then you have just damaged and taken 50,000 miles off the engine. You must get rid of it.
You can get a smallblock re-ring kit with cast iron rings, bearings and complete Felpro gaskets for anywhere from 60.00 to 100 bucks. Some extra add ons may include brass freeze plugs etc.
If you do anything past this, you may as well go for a real engine build.
I would gently hone the bores with a tapered hone just to eliminate the ridge and the protruding rust, not the pits. When the hone marks on the ridge start to merge with the rest of the bore, stop. You will see the ridge after you start. Then take a ball hone and get the crosshatch, trying to remove as little as possible. At this time you will see how bad the rust pitting is and make your decision to continue.
Then relap the valves by hand new umbrella seals, and general cleanup.
A double row timing set is cheap and worth it.
I've done several engines this way over the years and the result is predictable. In the worst case, they may burn a little oil between oil changes, but they won't smoke. In my case, they usually last at least 30,000 miles.
If your intent is truly till next winter, then this is an option, but don't consider it a rebuild.
I did a little more cleaning and the pitting doesn't seem to be all that bad, though it is very hard to measure. Besides the bearings, which I'll have to take a look at, I'm concerned about the rings. The pistons must be aluminum as there is no rust or corrosion visible, but the rings certainly won't be.
What's reasonable/acceptable? At some point these will do less damaging than honing will. Regardless, I'll have to check the bearings before moving forward.
I would say your back to this
