x-pipe pics needed
Old Feb 26, 2007 | 12:28 PM
marshrat99's Avatar
marshrat99
Default x-pipe pics needed
I'm going to have duals with an x-pipe installed this Wednesday and need some pics I can print to show the installer how to run. TIA
Old Feb 26, 2007 | 05:34 PM
vetteaddic's Avatar
vetteaddic
[IMG][/IMG]
Old Feb 26, 2007 | 06:44 PM
BKarol's Avatar
BKarol
Earlier this month:
http://forums.corvetteforum.com/show....php?t=1619613
Old Feb 27, 2007 | 12:02 AM
81cali's Avatar
81cali
Old Feb 27, 2007 | 07:35 AM
rweasterly's Avatar
rweasterly
Default x-pipe
i have pics if u want them but you can make your x-pipe without having to buy one...where th pipes come together in the back (under the spr tire) you can cut an oval out of the inside of both pipes and pull the together and re weld....i had to extend on muffler input end about 2 inches...but!!!!!! the rest of these picks that ave been posted are very nice too...*****.i did it this way because i used two single chamber flowmasters behind the crossmember for resonators,so tha took up that space good luck
Old Feb 27, 2007 | 07:37 AM
rweasterly's Avatar
rweasterly
one more thing i wish there was enough room behind the crossmember to install a dynomax x-muffler ...that would have been sweet but the way 81cali did his it may fit (where the cat. use to be)..... i will have to look... thanks again
Old Feb 27, 2007 | 08:15 AM
pws69's Avatar
pws69
Here you go....
Old Feb 27, 2007 | 08:26 AM
rweasterly's Avatar
rweasterly
ooo ok the 81 has a diffrnt crossmember .... much more room to work with
Old Feb 27, 2007 | 08:32 AM
panic's Avatar
panic
...here is my undercarriage 2 3/4'' exhaust with 3'' X pipe just after the crossmember...
Old Feb 27, 2007 | 01:59 PM
rweasterly's Avatar
rweasterly
ttt
Old Feb 27, 2007 | 05:44 PM
marshrat99's Avatar
marshrat99
Excellent. Thanks all. I'm off to the muffler shop tommorrow AM.
Old Feb 27, 2007 | 06:55 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Cool bunch of pics. Gives some good ideas here. I have always wanted to do this but for some reason just keep putting it off. marshrat99 be sure to take pics and bring to the thread along with your opinion of your new exhaust.
To x-pipe pics needed
