Dial indicating bellhousing
Old Feb 27, 2007 | 05:48 PM
JW714's Avatar
JW714
Default Dial indicating bellhousing
I need some how-to on this procedure.I tried search but to no avail.I know I originally learned of the need for this here on C-3 but I don't remember how.If anyone can direct me to this info or would be kind enough to fill me in I would really appreciate it....Thanks ....JW714
Old Feb 27, 2007 | 06:27 PM
3X2's Avatar
3X2
Here ya go!
http://go.mrgasket.com/pdf/BELLHOUSINGALIGN.pdf
Old Feb 27, 2007 | 07:16 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
These are pretty nifty. Lakewood makes them.
Old Feb 27, 2007 | 07:51 PM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by JW714
whats the best way to set up the dial indicator?I don't quite see how to position the indicator. If the magnetic base is off center on the flywheel then the reading would be invalid?Please help me understnd....Thanks....JW
Anywhere ANYWHERE you can set the magnetic base is good enough. the dial indicator will travel around the flywheel in a perfect circle. Just get the base good a solid on the flywheel with the dial indicator touching the inside of the bearing retain hole, at right angles to the surface you are measureing, zero the gage and turn away. It will travel in a perfect circle.
Old Feb 27, 2007 | 07:55 PM
JW714's Avatar
JW714
Default Thanks guys
I figured it out as I was typing..Thanks Norvil for the quick reply...JW714
Old Feb 27, 2007 | 07:57 PM
Binnie77's Avatar
Binnie77
Old Feb 28, 2007 | 12:02 AM
JW714's Avatar
JW714
Default Good pic thanks!!!
Got it now Thanks .Binnie 77 and NorvAl too!!....JW714
To Dial indicating bellhousing
