It seems that the Mark VIII is the popular fan to swap around here. (Due to its dimensions and CFM I'm assuming.) (4K+ CFM?)
But is that much airflow really necessary? I notice that most of the universal ones in my Jegs and Summit catalogs are rated at 2K-3K CFM. Would something like that work for a 450hp SBC without AC? (Aluminum radiator with a highflow waterpump)
The only downsides to a fan with that much power and pulling force...are noise, and power consumption. If you do upgrade to a MarkVIII fan I would suggest an upgrade to your charging system. A healthy upgrade is to a CS alt, either the 130 or 144. It's an easy swap and will give you plenty of amps.
They are known for over heating but there is a very easy fox for that that most of use are more than capable of doing, and a brand new GM CS130 is only like $70.
Why do you recommend a unit with known drawbacks? There are 100's of good units out there with no/little flaws.
Why is $70. a magic number?
80 amps at idle? Who idles around in a Vette?
$70 is half what a new CS144 costs, and anyone that drives in stop and go traffic at all is gonna be at an idle. If the electrical accessories are drawing more than the alt can produce at that idle then you're just draining the battery. I personally feel idle amps are more important than RPM amps.
i'm using the dewitts with 2 spal setup on a BBC with at least 450 hp. i've only run it on the road this year so far, and so far so good as it should be. but i don't think it has really been tested yet with summer and A/C. will have to wait for that
Too much talk about alternators, back on topic please.
If I go with a less powerful fan I might not need a new alternator. Has anyone successfully used a 2k-3k cfm electric fan with a potent small block w/o AC? (Also, my car has a manual trans)
I am going the Mark VIII route. Received my fan waiting for my DCC to arrive. I had already installed the 100 amp SI amp last year. I currently have a flex a lite extreme installed but have heard some good things re the Mark VIII and DCC.
I sell about 150 of these per year for four years straight and I've never (not once) had anyone tell me that it wasn't enought air. Spals' dual 11 fans produce 2760 cfm and pull 25 amps. I know the Mark V fans are real popular on the CF right now, mostly due to the cost, but I still don't think much of mounting methods I've seen when compared to the bracket system we have.
Note to the big air naysayers:
The dual fans GM uses on C5 Corvettes is only 1700 cfm with 450HP!
The extra airflow is for the a/c system--it throws alot of heat into the radiator.
I have yet to see the DCC supply greater then 50% to the fan--at 50% the fan is almost noiseless. Except when the motor is turned off--it sounds exactly like a jet engine ramping down--a coolness factor of '10'.
C5's have much better air intake to the radiator as well--which does not apply to a C3. They also are designed to run hotter. You're comparing apples to oranges.
I have a Dewitts aluminum radiator and since I put the new seals in, the fan doesn't come on at all at speeds over 30 mph. I have not tested in summer yet...
I have no idea--but by guess and golly I would say about the same as the flex-a-lites--maybe 1500-2000 cfm.
My goal by going the Marl VIII/DCC/Dewitts was to have a cooling system that would do the job with ease.
And there is certainly nothing wrong with that! My point is, and to answer the thread question, 2000 cfm with a good functioning radiator is plenty of air. You are proving that now.
I had flex 210's before--they did not cool enough
(240+) when the a/c was on. Now, if I had had one of your radiators it probably would have.
Tom do you sell the brackets alone..aluminum ones?
