Installing cam bearings.
Old Feb 28, 2007 | 08:37 AM
gbak's Avatar
gbak
Default Installing cam bearings.
Is there any advantage/disadvantage to align the cam bearings oil hole when installing the bearings in the block?
Old Feb 28, 2007 | 09:44 AM
dmaaero's Avatar
dmaaero
Hay gbak,
Mark where there at on the block before trying to install, make sure they line up !!!
Old Feb 28, 2007 | 09:46 AM
442olds's Avatar
442olds
Well if you don't align them with the oil hole in the block your cam bearings won't get oiled and that's not good.
Do you have a cam bearing installation tool?
Old Feb 28, 2007 | 09:59 AM
gbak's Avatar
gbak
Yes, I can borrow a tool from a friend.
To Installing cam bearings.
