Header install tech tip...
Old Feb 28, 2007 | 08:38 AM
GDaina's Avatar
GDaina
Default Header install tech tip...
When installing headers by yourself, it's a PITA, lining up the bolts, keeping the gasket from sliding...etc, etc.
Tip....get a bunch O rings that slip over the bolts....line the gasket to the flange, slide the bolts through, slip the rubber O rings on the bots. The Orings keep the gasket from moving. Now you can line up the header and get the bolts started. Once you fire the motor, the rubber O rings will melt.
Old Feb 28, 2007 | 08:55 AM
dannyman's Avatar
dannyman
I don't think I follow your logic. Would sooner temporarily secure gaskets with something I could remove before tightening studs, ie: rubber bands,string,etc.
Although, I will agree burning rubber is sometimes a good thing.
Old Feb 28, 2007 | 09:09 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Have you ever had deja vu where you think you may have read this somewhere before
Thanks for the tip G. I found that starting a couple of bolts in the header/head, you can slip the gasket down between them and they are held in place by the bolts/studs. If the gasket bolt holes are closed, then I cut them so they can slid into place
Old Feb 28, 2007 | 09:42 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Thanks George!!! Great idea!!!
I got another, but it's nowhere near as good. Most headers come with a package of header bolts. Lots of times it's a major pain, especially if you are doing it alone as you describe, trying to get the bolts started and hold the header and gasket in position all at the same time. Sooo...a trick I learned was to use a couple of studs threaded into the head and "hang" the header and gasket on those studs with nuts FIRST. Not only can you get the gasket on, but it makes it a lot easier to get the rest of the bolts on too. Then you can either leave the studs on (they work just like bolts anyway), or unthread them and install header bolts.
(Oops...that may be what Mike said above)
Dep
Old Feb 28, 2007 | 11:00 AM
'Bochawa72's Avatar
'Bochawa72
Default gaskets
I use some pretty cool fel-pro gaskets that will actually let you start the bolts then insert the gaskets. They are in an O shape with little wings that are like hooks on the sides. You simply slide the gasket in so that the hooks catch on the header bolts. So you get three gaskets per side instead of one big one. I can't seem to find the part number right now but they're out there.
-CR
Old Feb 28, 2007 | 11:51 AM
JoeRags's Avatar
JoeRags
-CR
Allows you to start the two outtermost bolts, then slip the gasket in.
Old Feb 28, 2007 | 11:56 AM
norvalwilhelm's Avatar
norvalwilhelm
I work from underneath, slide the header into place, start the back bolt and then let the header hang. All my gaskets have slots in the end bolts for I start the front bolt, slide the gasket over the 2 end bolts and proceed to add the rest. I also use lots of anti seize.
To Header install tech tip...
