Need Help. Installing A Power Window Motor
Old Feb 28, 2007 | 12:47 PM
TISQUICK's Avatar
TISQUICK
Default Need Help. Installing A Power Window Motor
HI . DOES ANY BODY KNOW HOW TO INSTALL A POWER WINDOW MOTOR ON A 75 VETTE?. I CANT SEEM TO GET THE 2 GEARS TO MESH? THANKS TISQUICK@AOL.COM
Old Feb 28, 2007 | 02:44 PM
cchristo's Avatar
cchristo
Try posting in the tech or general section. You probably won't get much help here.
Old Feb 28, 2007 | 02:46 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I sent it to the mods for movement a while ago.
Old Mar 1, 2007 | 12:09 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i just replaced my regulator and gears last night. i am guessing that all you need to do is loosen the bolt at the bottom of the door that holds the regulator on. with that loose it will let you wiggle the motor into place and then you can tighten it back down. hope this helps.
To Need Help. Installing A Power Window Motor
