Emissions Systems
Old Mar 1, 2007 | 07:14 PM
1973_Stingray's Avatar
1973_Stingray
Default Emissions Systems
How do you check whether the following are working or not?
Vacuum Advance
EGR Valve
A.I.R. Pump
Evaporator Canister
Thanks!
Old Mar 3, 2007 | 05:25 PM
1973_Stingray
Anyone?
Old Mar 3, 2007 | 05:40 PM
gerry72's Avatar
gerry72
Nearly all of this can be tested with one of those hand vacuum pumps, or if you're not concerned about precision, just a piece of vacuum hose and the will to suck. You can also just tap manifold vacuum if you don't desire to suck.
Vacuum advance: Remove the vacuum advance hose from the distributor. Put your vacuum hose on it. Start the engine. Draw about 10"hg or or more and listen to the sound of the idle speed up. If you have a timing light, the timing will show the advance.
EGR: Pull the vacuum hose off the EGR. Apply your own vacuum. If the idle faulters (it may even kill the engine) you know the EGR is functional.
AIR pump can be tested with a vacuum/pressure gauge. It should show about 2psi at 2k rpm. But if it weren't working, it would be making some horrible noises since it's a vane pump.
Evap canister is easy. If you smell gas when you park the car, it ain't workin'. It has only one moving part and that's a checkvalve where the large hose goes in. The only other part is a filter on the bottom that needs to be periodicially replaced.
Old Mar 3, 2007 | 07:01 PM
1973_Stingray
Thanks for the info.
Old Oct 25, 2016 | 10:21 AM
rpetronk's Avatar
rpetronk
Default do you have a vacuum routing diagram
I bought a 73' that appears to have vacuum lines moved.
Thanks,
-Ray
Old Oct 25, 2016 | 01:52 PM
MelWff's Avatar
MelWff
Default emissions diagram
this is for 75 but should be similar. You do realize this is a 9 year old thread.
Old Oct 25, 2016 | 02:49 PM
rpetronk's Avatar
rpetronk
Default emission lines
Thanks for the reply! Yes, I know its an old thread and I just gave it a shot.
I did see that diagram on a 75' and unfortunately its different. (no vacuum and time delay solenoid)
Thanks!
-Ray
Old Oct 25, 2016 | 03:19 PM
MelWff's Avatar
MelWff
then you need to purchase the 1973 Chassis Service Manual and probably the AIM
Old Oct 26, 2016 | 09:31 AM
rpetronk's Avatar
rpetronk
Default 73 manuals
that carb appears to be wrong for a holley
I have both the service manual and there is nothing on vacuum routing
I have the assembly manual that has a really poor illustration (I can't believe someone could have followed it in the factory)
Old Oct 26, 2016 | 11:03 AM
MelWff's Avatar
MelWff
are you saying you have a Holley?
if so why are you concerned about factory routing of emissions related vacuum lines?
Old Oct 26, 2016 | 11:34 AM
rpetronk's Avatar
rpetronk
Up until a few hours ago I bragged that I had a "numbers matching" 73 Vette. I forgot that I should have a Rochester carb. geez that's why the vacuum lines look different!
the car runs great I was just documenting all the cars' details just in case I develop an issue.
Thanks,
-Ray
To Emissions Systems
