Headlight stuck
Old Mar 2, 2007 | 04:45 PM
TotalC1971's Avatar
TotalC1971
Default Headlight stuck
I pulled my headlight up to look at it, now the darn thing wont go down. Car has no engine,electrical or vacuum. Is there a manual way to crank this sucker down? I dont want to whack it putting the new engine in!! PS. Its a 71 coupe
Old Mar 2, 2007 | 05:37 PM
tobyte1's Avatar
tobyte1
Get a Mighty-Vac or other vacuum source and plumb directly to the actuator.
Old Mar 2, 2007 | 05:50 PM
Gordonm's Avatar
Gordonm
Just reach up under and look at the hinge mechanism. You will see it has a "knee" action. Just push on the "knee" and it will relaese and then you can put the headlight down. Very easy once you have done this.
Old Mar 2, 2007 | 06:00 PM
427-390's Avatar
427-390
Been there, done that. Not a big deal
Good luck.
Old Mar 2, 2007 | 06:01 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
You can see the knee is going in the open direction in this pic. Hope this helps.
Old Mar 2, 2007 | 07:47 PM
TotalC1971's Avatar
TotalC1971
Default Cool!
Worked like a charm! Thanks!
To Headlight stuck
