Compression Test Question
Old Mar 2, 2007 | 10:59 PM
DO2G's Avatar
DO2G
Default Compression Test Question
Please confirm I am doing the compression test right....
1. Run engine until warm.
2. Remove all spark plugs.
3. Put the gauge in a cylinder
4. Press accelerator to the floor and try starting 5 times.
5. Write down reading.
6. Repeat in all cylinders.
Old Mar 2, 2007 | 11:09 PM
JoeRags's Avatar
JoeRags
Be sure to disconnect the ignition coil wire.
Cheshire huh? I grew up on Far Horizon Dr... live in Wallingford now.
Old Mar 2, 2007 | 11:12 PM
Big2Bird's Avatar
Big2Bird
Yep. This is the "Dry" test. You can repeat this test "Wet" with a shot of oil in the cylinder.
Old Mar 3, 2007 | 04:52 PM
DO2G's Avatar
DO2G
Thanks guys....
I did the dry test and it looked real good. 135-145 in all cylinders.
Old Mar 3, 2007 | 05:36 PM
happiedazs's Avatar
happiedazs
Why are you doing a compression test? What problem are you trying to solve?
Old Mar 4, 2007 | 03:11 PM
DO2G's Avatar
DO2G
No problems...I was just curious to the condition of the motor.
To Compression Test Question
