Differential Drain
Old Mar 3, 2007 | 09:12 AM
Puckboy's Avatar
Puckboy
Default Differential Drain
Corvette Fever February 2003 shows how to install a plug to drain the diff. Does anybody know the location were to drill the hole?
Old Mar 3, 2007 | 09:32 AM
noonie's Avatar
noonie
Try this
http://forums.corvetteforum.com/show...29&postcount=5
Old Mar 3, 2007 | 09:33 AM
parkerracing's Avatar
parkerracing
You can drill and tap it almost anywhere between the bolt holes. If you make a paper template, you can make a hole in the strut brace in the same place (only larger, so you can put a socket on it). That hole will usually determine where the one in the rear goes. /:\
Old Mar 3, 2007 | 10:05 AM
Puckboy's Avatar
Puckboy
Thanks for the info
To Differential Drain
