Help with cam selection for SB 400
I was looking for an engine stand to start the rebuild on my rusty 350 when what should I find:
Probably means a little more time and certainly more money, but this was the motor that I wanted to go with next winter when I had more time. By the way, thanks to Chevyreb for his write up the other day on these. Gave me a much better idea of the bad things to look out for.
The pistons are Speed Pro -12.5 cc dished.
Heads will be Edelbrock RPM 170 cc intake runner, 64 cc CC
Approx CR is 10.1 to 1
Edelbrock performer intake
Rough idle doesn't bother me but not enough vacuum to run my accesories does
Looking for low end grunt rather than a high end screamer
Preference is for flat tappet, hyrdaulic
I know that the heads are a little small for the block, but that's what I have. Should be very responsive at least.
Suggestions on cam or where to look?
I wish it was always that easy to find a good 400" short block.
As far as a cam selection, well 10:1 c.r. will support most any cam u want - big or small. smog requirements? U didn't list rear gear ratio or transmission so thats as far as a choice can will go and good luck with your new 400" short block.
cardo0
No smog requirements in California for 75 and earlier.
That's not entirely true. As I said, I'm much more interested in low end. Most of these components were chosen for 1000 RPM and up, though admittedly for a 350.
My wife assures me that my head is already too big.
-edit-Can you see a number in piston top ? ... Like H601 or H615 ... H601 uses short rod ... H615 uses 5.7" 350 rod.
also ... how much deck clearance does it have? ... how far down in hole is piston when @ TDC?
Haven't been able to measure deck clearance yet. There is no flex plate/flywheel or balancer on it so I can't easily turn it while it's hanging from the engine hoist. i'll check when I put it n the stand.
Is there an easy way to measure the connecting rods> Is the length center to center? (pin to journal).
Once you can rotate the motor ... and check deck clearance ... you might also check stroke/verify it has OE 400 3.75" stroke; unlikely but possible it's otherwise. In general, best to KNOW what you've got so you can better determine your best course as you plan for build. G'Luck!
