Engine Hot....hard to start
Here's the problem.....When the engine is cold, it starts up just fine (the choke sets and she fires right up) BUT after the engine gets to operating temps, she's a BEAR to start. It'll crank and crank and crank and crank and finally kick over. After that she runs like a "raped ape"...no black smoke, purrs at 650RPM in drive and runs really strong!
Here are the specs:
--- HEI ignition - Mallory Distributor (about 2 years old)
---350 with a Holley Street Avenger . The carb has been lately overhauled. I set the float level (the gas just dribbles out of the viewing hole with the engine running). I set the air/fuel mixture to get the most vacuum (14-15"). There's no dieseling or backfiring.
---I set the timing to 6.5*BTDC
---Changed the plugs in July of last year.
---New Taylor Stainless Steel braided plug wires (properly grounded).
I't just a PITA the start when hot..It's kinda embarasing when you jump in your Vette with a couple of Rustangs watching and you go to start and she goes "R-R-R-R-R-R-R-Varoom?"
Is the coil going out? I'm going to change the plugs again....looking for fouled plugs?
Do you have an electric choke on the carb? I had an issue where the electric choke kicks in even when the engine is up to temp. Makes it one hell of a PITA to start after shutting it down for a short period. I just disabled the choke... I really dont need it.
If it runs smooth (which it probably will) you've found your problem.
This same thing chapped my a$$ for a while. Finally got sick of it and safety wired the choke open, and disconnected power from the electric unit. Now, when cold, it takes a little feathering of the throttle to get her going good, but nothing that bothers me.
Do what panic does.
If you don't touch the pedal the choke won't reset the choke linkage. In addition you can either leave the key on a bit before you start the engine to heat up the elec element or let it idle a bit after it is started so it doen't reset to the choke setting.
BTW check you cold and hot settings first.
Do what panic does.
You could get by with a little more gap than people in the far north becuse of your location and temps.
Some people set it by the book though.
I don't use the choke at all where I live.
I would take a guess at vapor lock. Noting that you are in the sunny and warm south I would say that the heat from your block is boiling your fuel out. Pull your air cleaner cover and look down the carb while someone cranks. When you have a warmed up engine, ready to start, what happens when you pump the gas pedal without cranking the engine? Do you see fuel being squirted out and into the carb? If not, then you have a fuel starvation issue. The other thing is setting the fuel level. My Holley calls for setting the fuel level in the bowl so that is right at the base of the hole, not dribbling out.
Care to clarify to help narrow down the possibilities?
Thanks.....No, it's running fine after I get it started....it's just hard to start when it's hot or "up to temperature" and it sits for about 20 minutes. If I shut the engine down (after running it) and wait 2-5 minutes, she'll fire up just fine...but if it's sitting about 20-25 minutes, it'll will sound something like this...."R-R-R-R-R-R-Varoom"
Just thought of something that may help....about 3-4 weeks ago, I had to jump start the Vette (old battery + cold weather + not driving it for 2 weeks = slightly dead battery...since then I got a new battery)...anyway...I accidently put the positive lead from the other battery to the negative post on the Vette and vice-versa. Tried to start the car and realized "OH $hi#!!!
what I did wrong!!!!!!! Thank God nothing blew...no fuses, no fuseable links...nothing. Could that have weaken the starter???
