Hooker Side Pipes
Old Mar 4, 2007 | 12:29 PM
scottred80's Avatar
scottred80
Default Hooker Side Pipes
I'm getting ready to install new motor 1980, got a set of Hooker header / side pipes ,, ,,have Questions on install .... Have you guys put your header is the engine bay 1st before dropping in the motor , or can your install the headers after the motor is in ,, Help much appreciated. And are there any Obsticles that I need to be aware of during Install....
Old Mar 4, 2007 | 02:11 PM
Duke94's Avatar
Duke94
Set the headers in the engine bay then install the engine. Wire them up as necessary to keep them out of the way. Makes it much easier than doing it the other way around.
Old Mar 4, 2007 | 05:15 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
I was able to install the Hookers with my car just over 14" off the ground (measured from the ground to the frame just behind the front wheel). No problems.
Old Mar 4, 2007 | 07:51 PM
Sayfoo's Avatar
Sayfoo
I think both of the above answers are correct. I added mine a few years after a engine rebuild so I had a little different situation than you. I had the car about 24" up, and they went on alot easier that I thought they would, but why jack it up if you don't have to?
Old Mar 5, 2007 | 12:29 AM
sperkins's Avatar
sperkins
I put this set on with this much clearance. Drivers side was a little tough, but not too bad.
Old Mar 5, 2007 | 08:08 AM
bashcraft's Avatar
bashcraft
There's no reason not to put them in the engine compartment first. That takes 2 minutes compared to probably hours doing it the other way.
Old Mar 5, 2007 | 08:21 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Old Mar 5, 2007 | 05:06 PM
69vettester's Avatar
69vettester
You can install them before or after the engine, After may be easier, you wont have to pull them out of the way as your engine drops in.
Dont let the frame sag in any corner, that will throw the bolt up to heads dimension off a hair or two..
Heres some pics , similar jack stands as Sperkins and all the way up with everyone.
Old Mar 5, 2007 | 06:06 PM
Jack Jaeger's Avatar
Jack Jaeger
Great job, 69vettester. But what were Todd Christensen and Ken Stabler doing at your house? Or was that Kris Kristofferson and Nick Nolte? Or Terry Bradshaw and ....???lol!
To Hooker Side Pipes
