383 shortblock advice
Old Mar 6, 2007 | 04:27 PM
steve dalla's Avatar
steve dalla
Default 383 shortblock advice
Im ready to buy a 383 shortblock and am looking for advice. I want a street/STRIP motor runs pump gas but can be sprayed with 100 shot for fun. will top with 195 AFR heads. Please give opinions on who to buy from and what parts to be used. I want a shortblock and i can do the rest although i would like cam already degreed. thanks
Old Mar 6, 2007 | 04:45 PM
gkull's Avatar
gkull
Short blocks are usually cam less. I have installed a few cams without degreeing the cam. Degreeing the cam is more of an accuracy check. You are insuring that the cam is what the cam card says.
It is not a big deal to line up some dots and the timing chain paperwork will have a drawing.
just buy forged parts within your budget. lower grade or priced forged parts are better than the best cast or hyperthuretic(SP?)
Strong cranks are nothing when installed in a weak block. So I have always used ARP studs even in 4 bolt main caps
Old Mar 6, 2007 | 07:42 PM
b71vette's Avatar
b71vette
I recommend www.tandlengine.com. Ask to speak to Lloyd McLeary the Owner, tell him Larry recommended him. He built a 383 stroker for me turn-key in 05/2005, you should consider having him build you a turn-key or at least the long block and have him dyno/break it in. Unless you already have the AFR heads. I priced it out and could not have built it myself for what he charged and he included the dyno. He has an outstanding engine development facility.
Old Mar 6, 2007 | 08:10 PM
Gordonm's Avatar
Gordonm
I have a forged bottom end 385. Eagle crank, Scat stroker rods with 7/16 bolts and forged SRP pistons. A big solid cam and AFR 190 heads. It makes 400+RWHP and I would not hesitate to run a 150 shot of Nitrous on it. It was not cheap but not outragous either. I think I paid around 1700 for the stroker kit.
Old Mar 6, 2007 | 10:45 PM
bluegtp's Avatar
bluegtp
look in my signature for what I have done.....basically a cast bottom end.....I wouldn't hesitate to throw a 100 shot on the car.....I don't think I'd ever go much more than that though....
I've ran the crap out of this little motor for the past few months......for the price, you can't beat it for a street car.....i paid $540 for the stroker kit....cast scat crank, forged ibeams, HE pistons.......oh yeah, if it helps...it's a 2bolt main...note though, I built the motor and with this kit it does require clearancing...
ryan
Old Mar 6, 2007 | 11:51 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Eagle lightweight 3.75" 4340 forged crank Machined by AMS $400, Callies Comp star 4340 forged, polished 6" H beam stroker clearanced rods with the best rated 7/16 cap bolts. $720, Mahle forged flat tops with rings and pins $500. King bearings $60. Balanced easy with no heavy metal $200. Billet 4 bolt main caps $120. ARP Main studs $80, Line bore $100 Total Balanced, forged bottom end. $2180. Should handle lots of boost or a big shot of NO2 with no worries.
To 383 shortblock advice
