Smoke from the tailpipe ? help...
Old Oct 9, 2001 | 11:50 PM
SLVRCPE's Avatar
SLVRCPE
Default Smoke from the tailpipe ? help...
I have noticed recently my 74 is blowing out just a tad of smoke if I rev the engine 3k-4k rpm and let off sharply. I cant tell if the smoke is black or grey.. The engine has very low miles ( under 15k ) the engine lets off no smoke when started and no smoke at idle, also if I hold the engine steady at 3k-4k no smoke? As soon as I let off sure enough just a brief bit of smoke.. Am I dealing with a carb problem or something more serious??
327 .030
Holley aluminum 67CC heads. 2.02/1.60
Lunati cam .490/.490 1.6 roller rockers
edelbrock intake and 750 CFM Carb.
:confused: :confused:
[Modified by -HIC-, 3:52 AM 10/10/2001]
Old Oct 10, 2001 | 12:00 AM
SLVRCPE's Avatar
SLVRCPE
Default Re: Smoke from the tailpipe ? help... (-HIC-)
I need some help! _-Bump-
Old Oct 10, 2001 | 12:28 AM
marky mark's Avatar
marky mark
I'll take a stab at it. Perhaps it's a bit of oil finding it's way past the rings or perhaps the valves. It's not noticeable at low revs bat it only happens when you let off after revving. Why this might happen and if I'm even remotely close to being right will have to be answered by someone more knowledgeable than me. :chevy
Old Oct 10, 2001 | 02:56 AM
1979toy's Avatar
1979toy
Default Re: Smoke from the tailpipe ? help... (marky mark)
Do you have an automatic? If you do, replace the vacuum modulator.
[Modified by 1979toy, 1:37 AM 10/10/2001]
Old Oct 10, 2001 | 09:59 AM
SLVRCPE's Avatar
SLVRCPE
Default Re: Smoke from the tailpipe ? help... (1979toy)
This will help? have you seen this before?
Old Oct 10, 2001 | 10:58 AM
1979toy's Avatar
1979toy
Disconnect the vacuum line at the modulator. If it is wet in there, that is your problem. The engine sucks the transmission fluid into the intake manifold during periods of high vacuum (like rapidly getting off the gas), but just lets air bubble past the fluild during normal operation.
Old Oct 10, 2001 | 11:21 AM
79MakoL82's Avatar
79MakoL82
Could it be your carb going temporarily rich on acceleration? Maybe you need to lean out the carb a little. From the symptoms, I don't think it's oil related.
[Modified by 79MakoL82, 9:23 AM 10/10/2001]
Old Oct 10, 2001 | 11:48 AM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
I've been to the "bad modulator place"!:(
Smoke will usually be pretty grey, almost white. As has been mentioned, it sucks at high vacuum, so you sometimes see it on gearshifts etc. When it gets really bad you canm lay a nice smoke screen down:D Any wetness at the inlet manifold connection will indicate that this is the problem.
May help?
To Smoke from the tailpipe ? help...
