LOOSE MIRROR
Old Oct 10, 2001 | 12:07 AM
wadey's Avatar
wadey
Default LOOSE MIRROR
GUYS- JUST INSTALLED A PASS. SIDE CHROME MIRROR ON MY 76'.
IT LOOKS GREAT BUT SEEMS TO BE A LITTLE LOOSE WHERE THE
MIRROR PART CONNECTS TO THE STALK ( PIVOT BALL). IT IS LOOSE
ENOUGH THAT WHEN YOU SLAM THE DOOR THE MIRROR WILL MOVE
OUT OF POSITION. IS THERE ANYTHING I CAN DO TO CORRECT THIS?
THANX WADE
Old Oct 10, 2001 | 10:18 AM
Marks69BB's Avatar
Marks69BB
Default Re: LOOSE MIRROR (wadey)
Remove it from its bracket on the car and turn it the opposite way that it normally sits. Then use a hammer and a center punch to carefully put some nice dings on the ball to create more resistance. Reinstall and reposition your mirror; it should stay put for quite a while but may need another 'treatment' later on. :D :seeya
[Modified by Marks69BB, 8:18 AM 10/10/2001]
Old Oct 10, 2001 | 03:14 PM
Steve Grodin's Avatar
Steve Grodin
Default Re: LOOSE MIRROR (Marks69BB)
Another fix is to take the mirror out of the frame and tighten the metal strap. soak the mirror head in some laquer thinner overnight. You can then pop the glass out without breaking it. Use a punch on the two outside pins to tighten the metal strap. Use Automotive Goo or some such to glue mirror back on Mirror head will then be very tight.
Old Oct 10, 2001 | 03:36 PM
Matt Gruber's Avatar
Matt Gruber
Default Re: LOOSE MIRROR (Steve Grodin)
8 years ago i got 2 mirrors from wal-mart- $7.97 each. they have a screw to tighten to prevent movement :cool:
Old Oct 10, 2001 | 10:08 PM
76Pitter's Avatar
76Pitter
Had the same problems and tried all the tricks including epoxy but nothing
held it at highway speed. Out of exasperation I turned the mirror upside down and never had a problem since.
Old Oct 10, 2001 | 11:05 PM
HawkIVette's Avatar
HawkIVette
Default Re: LOOSE MIRROR (drives61)
WALMART!!!
BBBBB......U........U.....BBBBB.......BB BBB...............A
B........B....U........U.....B........B. ....B........B...........A..A
B.......B.....U........U.....B.......B.. ....B.......B..........A......A
BBBB........U........U.....BBBB......... BBBB............AAAAAA
B......B......U........U.....B......B... ....B......B.........A..........A
B........B.....U......U......B........B. ....B........B......A.............A
BBBBB.........UUU........BBBBB.......BBB BB.......A...............A
Old Oct 10, 2001 | 11:15 PM
daily_driver's Avatar
daily_driver
Default Re: LOOSE MIRROR (Rich's75)
well hey he didnt duck tape the mirror did he??
:conehead :conehead :jester :jester
Old Oct 10, 2001 | 11:31 PM
HawkIVette's Avatar
HawkIVette
Default Re: LOOSE MIRROR (daily_driver)
No, but probably used some 1/2" x 3" carriage bolts...... from the inside out!!!!!!
Old Oct 11, 2001 | 07:11 AM
Matt Gruber
i agree that the GM engineers were BUBBA's when they designed the stock miirror. But, hey fool me once, not twice.
No mirror problems in 8 years.
To LOOSE MIRROR
