Correct Rim Size for Tire ?
Old Mar 6, 2007 | 10:31 PM
Sub C 1's Avatar
Sub C 1
Default Correct Rim Size for Tire ?
Hi
I just had my 68's tires balanced and found out that instead of
having 7" rims all the way around, I've got 7" on the front and 8"
on the back.I've got Firestone Firehawk Indy 500's all the way around size 22570R15, and when I looked up the spec's on the tire to double check if 8" rims where OK with that tire it said that the recommended rim size was 6"-7.5". I was wondering if anyone has had any problems running tires on rims that weren't the correct size. I know its a stupid question, but the tires only have about 800 miles on them and I would rather put the cost of 2 new tires toward something else on the car. Any imput would be greatly appreciated.
Sub C 1
Old Mar 6, 2007 | 11:44 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
In 69 wheel width increased to 8" and stayed that way till 82. Several of the later year C3s had 225-70RX15 tires as standard equipment. No problem running the 8" rims.
Old Mar 7, 2007 | 07:28 AM
bashcraft's Avatar
bashcraft
I have 225-70/15 BFG's on 8" wheels and they're fine, but next time I'll probably get 235-70/15's
Old Mar 7, 2007 | 10:42 AM
Sub C 1's Avatar
Sub C 1
Hi
Thanks for the information.
Sub C 1
Old Mar 8, 2007 | 05:04 AM
WESCH's Avatar
WESCH
Hi
I just put on 235/70-15 in the front on 8" rims.
The shop had some problems to get the tires to seal initially to the rim for airing up. It required some brutal force to start sealing as the sidewalls are too narrow.
But once it sits on the rim, it looks great.
225 is a touch narrower , so be ready for some fighting.
Günther
To Correct Rim Size for Tire ?
