Electric fans
Old Mar 7, 2007 | 09:21 PM
coinwasher's Avatar
coinwasher
Default Electric fans
I got my new Dewitts radiator and fan unit (awesum unit) and I have one question. The radiator has a built in thermoswitch set to come on at 190 degrees. They installed that switch in the radiator with teflon tape on it so how does it make the ground through the tape? I am assuming that I need to ground the actual radiator as well.
Old Mar 7, 2007 | 09:41 PM
Big2Bird's Avatar
Big2Bird
That tape won't stop the threads from cutting thru and grounding.
Old Mar 7, 2007 | 10:17 PM
SIXFOOTER's Avatar
SIXFOOTER
Yep. The Teflon tape is just there to seal the voids between the threads on anything like that. You will see lots of posts in here to not use it on switches and sensors, but it will work just fine.
Old Mar 7, 2007 | 10:21 PM
noonie's Avatar
noonie
It probably doesn't need a ground
Maybe it's designed for "in series use".
What did the install instructions say?
Look up the part no.
Old Mar 7, 2007 | 10:42 PM
coinwasher's Avatar
coinwasher
The instructions said "do not use tape"
To Electric fans
