Bellhousing for 72
Old Mar 9, 2007 | 08:25 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Default Bellhousing for 72
Looking to buy a bellhousing for my sb 72, can someone tell me the correct size? I've seen 10" or 11" clutch assemblies? From 350 to muncie m 20. Also is it 26 or 27 input with 32 output splines for 72 only?
Old Mar 9, 2007 | 09:54 AM
Gordonm's Avatar
Gordonm
For a 72 it should be an 11 inch clutch with the bigger 621 bellhousing. The Muncie has a 26 input spline and a 32 output spline. Somewhere in the 70 model year it went from 10 to 26 input and 27 to 32 on the output. The later transmissions are a little stronger due to this change.
I have a 621 bellhousing. It had a slight crack at the bottom but I had it correctly fixed. It won't be NCRS bit it worked fine for a few years behind my motor.
Old Mar 9, 2007 | 10:06 AM
shafrs3's Avatar
shafrs3
You can find used ones on ebay, it doesn't have to be the exact "621" bell (last 3 digits of GM's p/n), just one that will accommodate an 11" clutch. Maybe someone who knows part numbers will chime in an give you some others that will work.
http://cgi.ebay.com/ebaymotors/GM-be...98718875QQrdZ1
http://cgi.ebay.com/ebaymotors/1969-...88871060QQrdZ1
http://cgi.ebay.com/ebaymotors/CHEVR...98496676QQrdZ1
You can also buy an improved thicker replica of the "621" from Keisler Engineering for about $240.
http://www.keislerauto.com/gm/transm...ellhousing.asp
Don't buy one that has been re-welded if you can avoid it.
Old Mar 9, 2007 | 11:28 AM
rj8806's Avatar
rj8806
Thanks Shafrs3 for the referral.
War Bonnet: We do have brand new replica 621's in house and ready to ship. Let me know if I can help you out.
Richard
Old Mar 9, 2007 | 03:47 PM
Don Rickles
2017 C3 of Year
Gordonm, Thanks for the info! These are concidered fine spline?
shafrs, Thanks for the referral and the links on Ebay! Now I've got some sources.
Richard
Thanks for the heads up on the new part, I'm going to try my luck used first, but your next in line if I can't find a good one!
Old Mar 9, 2007 | 04:39 PM
Gordonm's Avatar
Gordonm
Yes the 26 spline are considered the fine spline and the 10 spline is the coarse spline.
Old Mar 9, 2007 | 07:09 PM
sly vette's Avatar
sly vette
I got one for sale. Never been damaged Rings like a bell!!! $150+ ship. Bell has new fork boot also!! Powdercoated red. Insp cover comes with it also!
Old Mar 9, 2007 | 10:28 PM
Don Rickles
2017 C3 of Year
PM sent
To Bellhousing for 72
