How much clutch do I really need?
Old Mar 9, 2007 | 08:05 PM
'Bochawa72's Avatar
'Bochawa72
Default How much clutch do I really need?
I have a 72 with a 4 speed. I'm putting a 383 in shortly that will be about 420hp and 460 ft.lbs. I've talked to a few guys and some say 'You better get a serious clutch for that thing'. And other guys say I'd be just fine with a stock clutch. I don't plan on drag racing or taking it to the track. Perhaps an occasional auto-cross but not likely. It's mainly a cruiser/hot rod. So how much clutch do I really need? Is a centerforce DF overkill? I'd like to keep a somewhat soft pedal too.
-CR
Old Mar 9, 2007 | 09:21 PM
SIXFOOTER's Avatar
SIXFOOTER
Get the best you can afford
Old Mar 10, 2007 | 07:18 AM
Gordonm's Avatar
Gordonm
The stock clutch will not hold up to long. The CF dual friction is what I have and might be slight overkill but you will never have to worry about it.
Old Mar 10, 2007 | 07:55 AM
dr1's Avatar
dr1
The dual friction is not overkill for anything, thats why its half the price of any other "high performance" clutch you will look at :P
It will give you a lighter then stock pedal and decent grip though
Old Mar 10, 2007 | 09:12 AM
Vette Crazzy's Avatar
Vette Crazzy
USE NOTHING BUT A CENTERFORCE DUAL FRICTION.
VC
Old Mar 10, 2007 | 09:46 AM
Artsvette73's Avatar
Artsvette73
VC
Old Mar 10, 2007 | 10:31 AM
vetteaddic's Avatar
vetteaddic
I'm running Centerforce II behind my 427 sb with no issues and holds up well.The dual friction would be even better.
Old Mar 10, 2007 | 10:39 AM
b71vette's Avatar
b71vette
McLeod Pressure Plate and Dual-Friction Clutch, more expensive than some but well worth it.
To How much clutch do I really need?
