TH400 Deep pan question...
Old Mar 10, 2007 | 11:47 AM
1970-Bronze's Avatar
1970-Bronze
Default TH400 Deep pan question...
Can I just use the standard filter or do I need an different filter?
If it's a different filter, part number?
Old Mar 10, 2007 | 03:24 PM
C3 Stroker's Avatar
C3 Stroker
You can use the standard filter, but you must attach it to a longer pickup to reach the bottom of the pan.
Old Mar 11, 2007 | 09:34 AM
1970-Bronze
Does it need to reach the bottom?
I understand that the fluid will actually be cooler near the bottom but with the extra capacity the fluid will be cooler anyway.
Old Mar 11, 2007 | 12:59 PM
jackson's Avatar
jackson
Any top:bottom temp gradient will be insignificant ... remember, the fluid is just that ... it's fluid & moving about.
Use a stock filter & install it as stock.
If there isn't a magnet in bottom of pan ... install one.
Dunno how deep the pan is ... but keep in mind a C3 & it's OE pan is already low.
Instead of a deeper pan ... suggest you'd be better off with an auxiliary cooler.
Old Mar 11, 2007 | 01:16 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
We used to use the T-400 truck pans and they used a longer pickup tube/bolt to lower filter to bottom. Uses same filter.
JIM
Old Mar 11, 2007 | 03:00 PM
C3 Stroker's Avatar
C3 Stroker
JIM
This is the pickup tube I'm using also.
Old Mar 11, 2007 | 03:08 PM
C3 Stroker's Avatar
C3 Stroker
You should really extend the pickup so it reaches the bottom or you really haven't increased the capacity at all. It doesn't matter if you have 50 quarts below the pickup.....once enough fluid is in circulation to expose the pickup, you're screwed.
Old Mar 11, 2007 | 03:10 PM
1970-Bronze
Part number?
To TH400 Deep pan question...
