I think I'am vapor locking?
Old Oct 10, 2001 | 04:36 PM
Terrys69coupe's Avatar
Terrys69coupe
Default I think I'am vapor locking?
Working on my 68 454 project after about 5miles my car stalls out .I Have fuel pressure gauge and i thought maybe it was my fuel pump changed to carter 120 gph and 8.5 -9.0pressure.When car sits in my driveway temp jumps up to 210 and my clear fuel filter starts upfull but gradually goes to half to a quarter the more it idles .Did they run the fuel lines different for a big block seems like everything gets pretty warm under their in a hurry. thanks terry :smash:
Old Oct 10, 2001 | 04:55 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: I think I'am vapor locking? (Terrys69coupe)
I vapor locked once on mine. The fuel line was too close to the front of my header, just above the fuel pump. I wire tied it to the A/C bracket and no more problems. Look and see if you're close to the exhaust and if it is there's your problem.
Old Oct 10, 2001 | 05:26 PM
Z-man's Avatar
Z-man
Is your fuel line metal? I had similar problems and switched a part of the line (6 inches or so) to rubber since the metal got so hot. Haven't had any problems since.
Old Oct 11, 2001 | 04:44 PM
Terrys69coupe
Default Re: I think I'am vapor locking? (Z-man)
I'm running braided line up to the carb .Is their a wrap or something i can use to reflect the heat.I've seen stuff in summit and jegs just don't know which is best.
Old Oct 12, 2001 | 07:46 PM
Terrys69coupe
TTT :cry
Old Oct 13, 2001 | 01:56 AM
Terrys69coupe
Default Re: I think I'am vapor locking? (Ed T)
Theirs a oldie but goodie .God i forgot all about that little trick .Ill try that tommorrow (if it does'nt rain).Thanks alot. Terry :bb
To I think I'am vapor locking?
