A/C Compressor Screech
Old Mar 10, 2007 | 08:24 PM
Wrecked82's Avatar
Wrecked82
Default A/C Compressor Screech
Yesterday, the a/c compressor started screeching. Like the thing was not turning, but it was. Not frozen in place and the belt slipping. Same sound. But the compressor was turning, but a terrible screeching sound coming from internal (?). Sounds like not good news. Oh, not cool air either.
Old Mar 10, 2007 | 09:10 PM
gdm78vette's Avatar
gdm78vette
Mine did that years ago. The problem was the clutch. I took the belt off and it's been off since.
Old Mar 10, 2007 | 09:41 PM
tobyte1's Avatar
tobyte1
Does sound like the clutch. You can replace just the clutch, but a better bet would be to replace the whole compressor and recharge(and re-oil) the system.
Old Mar 10, 2007 | 09:49 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Had the very same thing happen to me.....replaced just the clutch....eventually had to repalce the whole compressor....should have done that to begin with....would have been cheaper in the long run.
Old Mar 10, 2007 | 11:36 PM
Artsvette73's Avatar
Artsvette73
Old Mar 10, 2007 | 11:55 PM
noonie's Avatar
noonie
If the sound truly was internal, then the compressor is junk.
Hook up gauges and pressures will tell you what's going on.
Evacuate system, remove oriface tube and check screen for debris. If any at all, then each componant has to be flushed properly and the compressor, oriface tube and dryer have to be replaced at minimum.
Old Mar 11, 2007 | 12:57 AM
Big2Bird's Avatar
Big2Bird
Old Mar 11, 2007 | 03:10 PM
Wrecked82's Avatar
Wrecked82
That's what someone at church told me.
Now to save up the shekels.
To A/C Compressor Screech
