Front Alignment
Old Mar 11, 2007 | 09:44 AM
BARRY L-48's Avatar
BARRY L-48
Default Front Alignment
When tearing apart my 80 for front suspension rebuild,I did not tape the shims and now as I am putting it back together,I have no idea which shims went where,should I just leave them out and tighten down the bolts or is there a way to set it up,either way a trip to the alignment shop is in order.
Old Mar 11, 2007 | 09:57 AM
Durango_Boy's Avatar
Durango_Boy
Without knowing where they were, your best bet is letting an alignment shop do the adjustments.
Old Mar 11, 2007 | 10:55 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
To get it close enough to drive, put say two 1/8" shims in the rear and one in the front, check the camber with a level and go from there.
To Front Alignment
