Suspension Install QA
Old Mar 11, 2007 | 09:18 PM
The3's Avatar
The3
Default Suspension Install QA
Can someone tell me if my tie rod is installed correctly? Do I bolt the end joint on top or below the steering rod that is connected to the spindle? I have an AIM and believe I installed accordingly but, it doesn't look right to me. Logical geometry tells me it should be on top. It would also help if someone could post some pictiures of a spindle assembled. Thanks.
Old Mar 11, 2007 | 09:38 PM
Durango_Boy's Avatar
Durango_Boy
You have it right, they come from under just like that.
Old Mar 11, 2007 | 09:39 PM
petronix's Avatar
petronix
You have it oriented correctly.
Old Mar 11, 2007 | 09:45 PM
tellcom2001's Avatar
tellcom2001
Old Mar 11, 2007 | 09:53 PM
The3's Avatar
The3
Thanks guys. The AIM is a good piece of gear but doesn't show the detail in spindle assembly.
I got a lot done today to include installing the suspension and finishing the cooling and alternator. Hopefully it fires this weekend.
To Suspension Install QA
