Coil Spring Install tool
Old Mar 12, 2007 | 08:05 AM
tomard's Avatar
tomard
Default Coil Spring Install tool
Will the loaner tool at Autozone do the job, to remove old/install new springs?
Old Mar 12, 2007 | 08:09 AM
jnb5101's Avatar
jnb5101
a lot of guys use a piece of threaded bar thru the shock tower and a pulley on the spring end.
Old Mar 12, 2007 | 08:55 AM
dannyman's Avatar
dannyman
Right you are, threaded rod worked for me.
1 Rod, 2 drilled steel plates, few washers and nuts.
Super safe !! Use a wrench, no impacts!!
Old Mar 12, 2007 | 09:00 AM
GDaina's Avatar
GDaina
The tool will do the job, just rotate the arms so that the rod is close to vertical/straight as possible.
Old Mar 12, 2007 | 09:22 AM
Hammerhead Fred's Avatar
Hammerhead Fred
My local NAPA has the tool available for loan as well.
Old Mar 12, 2007 | 10:49 AM
gkull's Avatar
gkull
I have never dorked around with a coil spring compressor on my 79 Vette.
You just put two jack stands up front. Remove both front wheels. Put a floor jack under the A-Arm and remove the shock/sway/steering arm......blah blah blah lower the floor jack and the spring falls out. Put the new spring in place in the a-arm slot while jacking the a-arm up.................... Probably 15 minute job per side with air tools.
The tapered steering joints come appart with a few good whacks from a hammer on the side.
Old Mar 12, 2007 | 11:33 PM
tomard's Avatar
tomard
Default Damn Tight
I couldn't get the teeth of the loaner tool to go high & low enough to compress the spring enough .... I think that the drilled dual steel plate idea with the threaded pipe would probably work best ....
How about some dimensions to I can make one that I know will be safe/strong enough????
Old Mar 13, 2007 | 01:01 AM
mkflanagan's Avatar
mkflanagan
You just put a two jack stands up front. Remove both front wheels. Put a floor jack under the A-Arm and remove the shock/sway/steering arm......blah blah blah lower the floor jack and the spring falls out. Put the new spring in place in the a-arm slot while jacking the a-arm up.................... Probably 15 minute job per side with air tools.
Same here on my 76.
Old Mar 13, 2007 | 01:17 AM
Z-man's Avatar
Z-man
As long as your engine is still in...
Old Mar 13, 2007 | 08:09 AM
jnb5101's Avatar
jnb5101
get a 36 inch section of threaded rod (not pipe) from your home supply store. i used 3/4 inch. get several washers (three on each end with grease applied-you're going to have a lot of friction when you compress that spring) and nuts for both ends. i used a double thickness of 2X4 wood for the bottom side under the A arm. remove the shock, measure the length of rod and cut, and replace with the threaded rod. assemble with washers and nuts, and you're ready to go-i recommend a safety chain, also.
Old Mar 13, 2007 | 08:34 AM
gkull's Avatar
gkull
That is the whole problem. Not enough room between the A-arms. If you read what i said and do it. It will all make sense. I bottomed out a stock length shock and blew it appart out at the track with my 550 inch pound springs. With simple tools and a parts runners I had it going again with borrowed stiffer springs
Old Mar 13, 2007 | 09:23 AM
dannyman's Avatar
dannyman
I seem to recall about a 3 foot rod, 3/4" thread. I used steel plates from a spare basement jack post. First, I removed the shock then assembled the unit through the center of the coil, one plate going on top of upper a-arm and the other plate below the lower a-arm.
Old Mar 13, 2007 | 11:23 AM
jnb5101's Avatar
jnb5101
i forgot-be sure to use a long enough section of threaded rod so that you don't run out of rod as the spring relaxes!
Old Mar 13, 2007 | 01:22 PM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
I'm curious to know if you have stock length springs?
Old Mar 13, 2007 | 01:51 PM
gkull's Avatar
gkull
Well at one time I had my 79 l-82 stock springs. The VB&P 550 inch pounds are one inch shorter. But I have also had to use up to 1 inch spacers with small diameter front tires for ground clearance and now 3/8th spacer for tire/fender clearance with tall 17 inch wheels and tires
Old Mar 13, 2007 | 02:14 PM
mudbone64's Avatar
mudbone64
The reason I was curious about your springs is because there was no way to insert my spring (72 454 coupe) into the spring pocket and jack-up the lower control arm. The spring was just too long. I have a friend with a 67 GTO and he told me to do the same thing you were suggesting. For me it just wouldn't work. Don't get me wrong, I'm not disputing your word or your method, I just wish it had been that easy for me because I didn't like using the spring compressor and an air-impact to compress what essentially became a bomb.
Spring compressors can be difficult to work with as you may have to re-postion them several times before the whole system works. Most of the guys I know use the threaded rod solution.
mudbone64
Old Mar 13, 2007 | 02:22 PM
gkull's Avatar
gkull
Are you knocking out the lower steering arm? The A-arm should swing way down. I also pull the caliper, so it is not hanging by the brake line.
To Coil Spring Install tool
Old Mar 13, 2007 | 03:23 PM
mudbone64's Avatar
mudbone64
Yes. I had my front suspension completely disassembled for repainting. From what I remember (this was a couple of years ago) the spring extended below the shock-absorber opening on the lower control arm. Because of the spring length ther was no way to "swing" the control arm under the spring. I believe I have the factory installed springs in my car as they still had the identification tape still attached.
Old Mar 13, 2007 | 03:36 PM
gkull's Avatar
gkull
The quick fix for you is: Cutting torch! Then get some real springs like the 550's to support the BBC. I almost wonder if along the line some Bubba just installed some El Camino springs.
Old Mar 13, 2007 | 04:12 PM
mudbone64's Avatar
mudbone64
I suppose anything is possible. And quite possibly Bubba did install El Camino springs on my car. The car does seem to be fairly unmolested with 51k on the clock though. Perhaps somone else can comment on the use of a jack rather than a compressor or all-thread to install springs.
