Key will come out....
Old Mar 12, 2007 | 01:12 PM
jim2527's Avatar
jim2527
Default Key will not come out....
This is the first problem with my car.....so far.
1970 4sp. w/ tilt tele.
When I turn the car off the key doesnt turn back far enough to remove it from the column. I'll assume theres an adjustment somewhere. I do know the shifter linkage needs work but it does shift (roughly) into all the gears....
Any help is appreciated...
Jim
Old Mar 12, 2007 | 02:17 PM
Ray Y's Avatar
Ray Y
Make sure you it in reverse or the lock out will not let you remove the key with a 4 spd.
Old Mar 12, 2007 | 03:00 PM
jim2527's Avatar
jim2527
I tried it in reverse and still couldnt get the key out. I know I need to rebuild the shifter. Is it safe to assume this is a mechanical adjustment?
Jim
Old Mar 12, 2007 | 04:17 PM
Jim Shea's Avatar
Jim Shea
There is a cable coming from the reverse lever on your transmission. It comes up and attaches to a lever on the lower end of the steering column. If you open your hood, the lever can be seen just under the brake booster.
That column lever has to be in the full UP position in order for you to be able to rotate your ignition lock cylinder all the way to OFF-LOCK or ACCESSORY.
The cable could have become disconnected. The cable could be frozen from age. Bubba may have disabled the cable. Or any number of things in the last 30 some years.
Here is a link to a paper on the Corvette Steering Column to Transmission Interlock System.
http://jimshea.corvettefaq.com/wp-co...tems27JL04.doc
Jim
Old Mar 12, 2007 | 07:48 PM
jim2527's Avatar
jim2527
This cable?
Thanks for the help!!
To Key will come out....
