Gas Tank Problems? HELP!
Old Oct 11, 2001 | 07:13 AM
MassVette's Avatar
MassVette
Default Gas Tank Problems? HELP!
Well, I installed an Edelbrock C-66 dual quad manifold with 2- 600 cfm Edelbrocks and progressive linkage on the ZZ/502. We put it on, dropped in the distributor, and it fired right up with next to no adjustments! What a SMOOTH running setup! It was a real pleasure to drive--no coughing, bogging, flat spots, erratic idling, nothing- just as smooth as silk. And what a kick in the azz when you tromped the pedal!! After taking it on a cruise to Gloucester with the Corvette Club, I returned using less than 1/4 tank of gas (I was very careful to stay on the primaries and keep it in overdrive to check mileage on the way back- all highway driving).
However, the idle seemed rich so I changed metering rods (following the Edelbrock charts). It seemed to be a step in the right direction. The next step was to replace the primary jets with ones .002 sizes smaller. This was done, and the car seemed OK, except that it was uneven in "off idle" mode. Fine. Went back up on the metering rods. No change. Still felt uneven;
While idling, the motor had just quit-like running out of gas. After getting it going, I checked the fuel pressure gauge-3 lbs! I adjusted the regulator for the electric pump-wouldn't respond! I replaced the gauge with a new spare-no difference! Next, I replaced the electric fuel pump with the new Holley 'blue' that I had taken off because of noisy operation. There was NO gas coming out of the fuel line! Empty tank! What a moron! The gauge said 1/2 a tank. Must be a faulty sending unit;
I sent a guy to the gas station for $5 worth of gas, and proceeded to blow out the fuel lines with compressed air. I installed the pump, hooked up the lines, put in the gas and fired it up. No problem, it started and ran smooth as silk! After adjusting the idle, I got in and started for the gas station- it DIED, just like the other times! No fuel pressure! Pump sounded funny, too; Got it running and got gas; It took 10 gallons and kicked off-- tank was full! The sending unit WAS OK!
Does ANYBODY have any idea what gives here???????? HELP!!!!!! Could it be the tank bladder?
:crazy: :chevy :crazy:
Old Oct 11, 2001 | 07:43 AM
daily_driver's Avatar
daily_driver
Default Re: Gas Tank Problems? HELP! (MassVette)
what year is your car??
i think only 75-77 had bladders
i know 76 for sure cuase thats what i have...
usually when the bladder collapses it gives you fill problems ..not being able to fill it all the way up..
the inlet has a big "sock" screen thingie on it so i seriously doubt that the bladder wouldbe getting in the way of the inlet if thats what yer thinking.
perhaps that line is plugged up in the sending unit?? thats possible....or that little sock thingie....
Old Oct 11, 2001 | 08:25 AM
MassVette's Avatar
MassVette
Default Re: Gas Tank Problems? HELP! (daily_driver)
The car is a 1979 Corvette.
:chevy
Old Oct 11, 2001 | 01:00 PM
tunedport78's Avatar
tunedport78
That little sock thingie is still available from GM for about $10. I don't know the part number tho
Vic
To Gas Tank Problems? HELP!
