intake manifold gasket thickness ??
I noticed that the manifold sits very low, even with the old manifold gaskets in place the boltholes don't line up, still too low. The gaskets I'm using are .060".
I saw that these gaskets are available in several thicknesses up to .120", for example Mr Gasket MRG-106
Is it "normal" that I need a .120" thick gasket ??? I'll be using RTV at the front and rear of the block so that's no big deal - The block was decked to 9.010" so the heads sit a little lower than 'stock' (.015") - I didn't expect that to make such a big difference on the manifold position - any thoughts ??
