68 vs 69 E-Brake console
Old Oct 11, 2001 | 12:16 PM
David68's Avatar
David68
Default 68 vs 69 E-Brake console
Knowing that the 68 e-brake console is unique, is the reason solely due to the receptacles for the seat belt latch or is there something else? I've received a `68 correct console with the receptacles which in my situation are not needed but I prefer the cleaner look of later consoles. Do later year models share the same mounting points, etc?
Thanks.
Old Oct 11, 2001 | 12:35 PM
68shark's Avatar
68shark
Default Re: 68 vs 69 E-Brake console (David68)
I believe they are interchangeable. Mine is a very late production '68 (built Aug '68) and has the later version e brake console with no receptacles. I was told that it had not been replaced and was original (it does look it and has aged same as rest of interior).
Old Oct 11, 2001 | 01:43 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Mine is an original with the buckle pockets and I used it to replace a banged up '69 or later unit which was in the car when I got her. With the exception of the buckle pockets and possibly the graining pattern, there probably isn't much difference among the model years.
[Modified by Easy Mike, 11:44 AM 10/11/2001]
Old Oct 12, 2001 | 06:49 PM
Juliet's Avatar
Juliet
Beware that the reproductions (Both Corvette America and ECProducts) for 1970 consoles are absolute CRAP. I returned them both and have my cracked original back in there instead. I tried in vain to find a decent condition used one at Carlisle this year. :( I may have to reattempt my original repair as it didn't hold up well once I bolted the metal underside stuff to it. :(
To 68 vs 69 E-Brake console
