Cooling Problems
Old Mar 14, 2007 | 01:04 PM
79corvette's Avatar
79corvette
Default Cooling Problems
I am having some cooling problems after installing a Mark VIII fan and a DC Controller. I think the problem might be my water pump, but I am not sure. I let the car idle to heat up and open the thermostat, eventually the fan came on but my tempeture gauge was reading above 200. I think the fan also shut off shortly after (needle above 200). When the fan was on it did not seem to have any affect on the temperture gauge (kept climbing). I shut off the engine when the needle got very close to the red. When the fan was on it did seem like it was moving a lot of air.
I figure it might be the water pump because I assume my new fan controller is working and cooling off the water in the radiator and that the water in the block is not flowing. Does this seem logical? Thanks for the help.
Old Mar 14, 2007 | 01:22 PM
SIXFOOTER's Avatar
SIXFOOTER
Sounds like you might have air in the system. When you check it out next, open the radiator cap and make sure you can see fluid moving when the t-stat is open. Drilling a small hole in the t-stat is a good way to get the air to bleed out. Sounds like the controller is working if the fan cycled on and off. Where did you install the sensor?
Old Mar 14, 2007 | 01:45 PM
79corvette's Avatar
79corvette
I installed the sensor on the lower right side. Pretty close to the bottom outlet.
Old Mar 14, 2007 | 03:27 PM
SIXFOOTER's Avatar
SIXFOOTER
Thats a good place for it. Check out the air pocket issue, my bet would be there. The T-stat is always a suspect when the temp tends to climb. Remember the temp gauge reads the temp between the center cylindars on the head, which will be the hotest part of the engine. With the fan upgrades you have done you should be good, water pumps usually leak when they fail, so if its not leaking I wouldn't suspect the pump. Replace the t-stat and drill a 1/8" hole in it to bleed off the air. Problem should go away
Old Mar 14, 2007 | 03:46 PM
PhotoVette1's Avatar
PhotoVette1
Feel the air coming out of the fan.
Check and see if the airstream is coming straight out of the fan.
Or, does it deflect to the sides instead of straight out? If so, the radiator fins are clogged with debri (on the outside.)
Old Mar 14, 2007 | 04:51 PM
79corvette's Avatar
79corvette
Thanks guys for the help. I bought a new 180 degree thermostat and drilled a coupld holes in it. I will be installing it tomorrow, got to paint some of the house tonight. The air comes straight out of the fan. The fins should be good, it is a fairly new aluminum radiator. The fan really pulls air through when it comes on full, atleast I know something is working properly lol.
Does a water pump actually go bad (as in stops flowing water) or does it just leak?
Old Mar 14, 2007 | 04:56 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Why at the outlet of the radiator? Tom mounts his at the inlet; the fan should work in conjunction with the T-stat. I am not familiar with the DC controller, does it start the fan at low speed and ramp up from there. Set the fan to come on just below the T-stat temp and ramp up from there, let the radiator and T-stat do the work and than use the fan when it is needed.
Neal
Old Mar 14, 2007 | 06:49 PM
79corvette's Avatar
79corvette
Neal
The instructions told me to place it in that area. I think it is placed there this way the fan only runs when the flow of air from driving isn't enough. The DC controller is a variable speed controller, starts slowly and varies the current. The conroller was set to hold the engine at 180 and the T-stat was 195 (the new T-stat I bought is a 180).
Old Mar 14, 2007 | 06:55 PM
Ironcross's Avatar
Ironcross
I`m nearly 100% sure that the water pump is ok. They keep on working even when they are leaking from the shaft seal.
Old Mar 14, 2007 | 07:19 PM
PhotoVette1
Neal
The outlet of the radiator is the correct place for the sensor for the DCC; I have his same setup.
Old Mar 14, 2007 | 10:55 PM
SIXFOOTER's Avatar
SIXFOOTER
True story, water pumps pump and don't leak or they work and leak
Old Mar 14, 2007 | 11:22 PM
Old Mo's Avatar
Old Mo
Water pumps can be bad . Not supply enough flow threw the system. They are a centrifical pump and if there is too much clearance between the impeller and the housing flow will deminish. This is not an uncommon problem with rebuilt water pumps. This will usually be noticed by the engine running cool at higher rpms but heating up at lower rpms.
Old Mar 15, 2007 | 03:00 PM
Ironcross's Avatar
Ironcross
I dont agree with that statement at all. We have sold hundreds of rebuilt waterpumps without any serious problems as long as properly installed. I have seen pumps with the hub broken off but those problems are normally caused with improper belt tension by DIYS`s. Even with a leaking bad hub seal all thats necessary in an emergency is to turn back the radiator cap to it`s first notch to remove the pressure and let the system go along for the ride until back to home base and repaired.
To Cooling Problems
