Block Fill??
Old Mar 15, 2007 | 08:29 AM
Edzred72's Avatar
Edzred72
Default Block Fill??
Looking at a race prepped block locally that is half filled.....
All I know is that it stiffens the block for racing, but would like more info please. Would a half fill be OK for the street? Oil/coolant overheat issues durring extend use? Can it ever be removed? Enlighten me guys....
Eddie
Old Mar 15, 2007 | 08:37 AM
HDIronman's Avatar
HDIronman
I did a half fill in the last block that was in my vette. Reason was I had two sleeves put in and the fill stiffened the lower portions of the cylinders. I had no issues with temps. It cannot be removed once it's in there.
Old Mar 15, 2007 | 12:12 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've been kicking around the idea of doing it on my 400.
Old Mar 15, 2007 | 12:16 PM
LemansBlue68's Avatar
LemansBlue68
Is the block half full?....Or half empty?
I'm thinking of doing this for a 400 block I have too by filling up to the freeze plugs. I wouldn't have any reservations about doing this for a race motor but was wondering how many were using this on the street and how it was working out for them.
Old Mar 15, 2007 | 02:03 PM
Edzred72's Avatar
Edzred72
Anybody running a fill on the street...in heavy traffic...with high horse motor???
E
Old Mar 15, 2007 | 09:20 PM
Edzred72's Avatar
Edzred72
E
Somebody...anybody???
Eddie
Old Mar 15, 2007 | 11:06 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Forgeddaboudit you don't need it
Old Mar 16, 2007 | 08:44 AM
Edzred72's Avatar
Edzred72
But ohhhh the price is so right for a fully machined ready to hone & go splayed, bored, clearanced, magged, deck plugged block....
Eddie
Old Mar 16, 2007 | 09:28 AM
jackson's Avatar
jackson
I dunno eddie ... it MIGHT , MAYBE come out if block was baked & blasted ... just dunno.
Might be worth a call to your local machinist to see if they've had any experience w/ bake &blast on filled blocks.
Old Mar 16, 2007 | 10:18 AM
gkull's Avatar
gkull
It is a very good idea when you you use 3.875 or 4 inch stroker cranks. I never had heat issues. You have to think about how only the upper part of the cylinder wall is subjected to the heat of the gas firing.
Old Mar 16, 2007 | 12:13 PM
MotorHead's Avatar
MotorHead
Eddie
I didn't read your post entire post, I thought you wanted to fill the block you had already. I have no experience with half filled blocks so I can't give you any advice. I do know you see them on the track all the time, but not so common on the street
Old Mar 16, 2007 | 12:16 PM
C3 4ME's Avatar
C3 4ME
reading this thread with interest, I've never heard of filling a block, so I'm curious to learn more.
Old Mar 18, 2007 | 08:41 PM
uglyc3's Avatar
uglyc3
1st Gear
Filling a block strenghtens it, my reccomendations are to use HardBloc since to the best of my knowledge it's the only one compatable with antifreeze. a half, or short fill is to the bottom of the freeze plugs and personally i'd reccommend it on anything making over 500ft/lbs or above 7k rpms since it will keep the block from twisting and make the crank live longer. don't worry about overheating, for the most part heat is only made in the first inch of the bore, you'll have about 2.5 or more of anti freeze to keep it cool, if your really worried about it get a high flow water pump
Old Mar 20, 2007 | 02:19 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I haven't used it on my Chevy, but I half filled my Oldsmobile block this time around. Haven't had it out yet, but it is a street/strip car.
Old Mar 20, 2007 | 04:09 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Everything I have been able to find is that filling it up to the freeze plugs is just fine in a street car. I fully intend to do it when I send my block to be machined and prepped.
To Block Fill??
