Diff oil
Old Mar 15, 2007 | 08:18 PM
kayosnes's Avatar
kayosnes
Default Diff oil
Anyone who have used quaker state limmited slip diff oil?
It is now filled w\ the standar GM oil. + addetive. I filled this in after i had changed gears, clutch, bearings++ in the diff.
I have problems with getting the GM oil here in Norway. So i am evaluating to change to quaker state limmited sli oil after 500miles. (I have installed a screw in the diff, to easy be able to make oil changes.)
It also stands on the quaker state bottle, that no addetive is needed.
Any recomandations? Any experience w\ quaker state oil in the diff?
Old Mar 15, 2007 | 08:32 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Don't know about Quaker State, but a respected builder over here swears by LUCAS Oil 85/140. That is what I will be using!!!
Old Mar 17, 2007 | 01:38 AM
kayosnes's Avatar
kayosnes
You use addetive with that oil????
Old Mar 17, 2007 | 08:31 AM
DIP51's Avatar
DIP51
It says you don't need to but I put a bottle in anyway!!!
Old Mar 18, 2007 | 12:41 AM
kayosnes's Avatar
kayosnes
guess i will try whitout first. And then use addetive if any problems occurs
Old Mar 18, 2007 | 11:08 AM
Donald #31176's Avatar
Donald #31176
Kayosnes,
Use the GM axle oil or a commercial SAE 80W-90 GL-5 gear oil along with s 4-oz. bottle of limited slip additive.
Short fill the axle a few ounces. If you get chatter, add 2 more ounces of additive and test. Once sufficient additive is present to prevent chatter, top off the axle. Maximum level should be to the bottom of the fill plug WHEN THE OIL IS HOT - slightly below when cold. Minumum hot level is a quarter-inch below the fill plug. Axle capacity is 3.7 pints.
It's best to use the minimum amount of additive required to prevent chatter. Excess additive reduces clutch preload torque.
To Diff oil
