Removable Rear Window
Old Mar 16, 2007 | 01:01 AM
pipervette's Avatar
pipervette
Default Removable Rear Window
How easy / what mods are required to swap out a fixed rear window and put in the removable option from the early 70's models?
Old Mar 16, 2007 | 07:43 AM
1B.DZ's Avatar
1B.DZ
I'm interested as well.
Old Mar 16, 2007 | 08:29 AM
Edzred72's Avatar
Edzred72
Not difficult...but can be expensive. You will need the rear glass & frame which is not reproduced and can be hard to find in good shape. Latches, (uppper roof) receivers, (lower window frame) and rear roof panels that are notched for the latches. The glass weatherstripping aslo must be changed. Many here have done it, and I've heard the holes for the latches are already in the roof frame on some cars. Not hard to drill if they are not. If you want the rear window tray to carry your glass, they too can be expensive and hard to find in good shape.
Good Luck
Eddie
Old Mar 16, 2007 | 08:40 AM
Niart01's Avatar
Niart01
Default Rear window
I did it to my 73. It took less than 1 day to complete. I bought the window off of Fleabay for $85. I bought the laches from Fleabay for $35
I was replacing all of the weatherstriping anyway so I bought a 72 gasket from Zip. The holes for the bottom tabs are in you car, and the place to mount the latches are up under the headliner panels. The only glitch was the window gasket is too big. I started at one corner and glued the gasket to the bottom and sides. I cut the gasket at the top in the middle so there would be no leaks at the bottom. Best $100 I have spent. The window does not leak at all. The window only goes back in for winter storage. I have it out most of the summer (unless I get caught in he rain). If you can find all of the parts DO IT. I saved the original as the next owner may want to return it to stock.
Old Mar 16, 2007 | 09:39 AM
Artsvette73's Avatar
Artsvette73
Did it to my 73 The part that takes the longest it securing the weatherstrip.
Old Mar 16, 2007 | 10:54 AM
surgn's Avatar
surgn
Anyone know if this can be done to an '81?
Old Mar 16, 2007 | 10:57 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
http://forums.corvetteforum.com/show....php?t=1603168
Old Mar 16, 2007 | 11:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Could probably be done, but would be very expensive. Rear quarters changed in '78 to accomodate the big back window, including frame changes and changes to the location of the fuel tank. You'd be looking at retrofitting 68-77 rear quarters to an '81, in addition to obtaining the pop out window and all the associated hardware. You'd also be losing a heckuva lot of rear storage space and most of your rearward visibility. You'd need exterior paint.
IMHO -- not worth it. Keep the big back glass in the '81.
Old Mar 16, 2007 | 11:28 AM
surgn's Avatar
surgn
damn!
Old Mar 16, 2007 | 12:07 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
http://forums.corvetteforum.com/show....php?t=1591575
Old Mar 16, 2007 | 10:02 PM
carl a's Avatar
carl a
from what i understand the reason it was changed in 73 was the t top blew off at high speeds, since i do 145 + in mine,, like not even battin a eye, im leavin my fixed window in, i d like to keep my t tops
Old Mar 17, 2007 | 12:08 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It was SUPPOSEDLY done because driving with the window out caused too much noise and cabin turbulence. I'm sure the real reason was because it was much cheaper to just glue in a flat piece of glass.
Old Mar 17, 2007 | 12:37 PM
Corvette Charlie's Avatar
Corvette Charlie
I Heard Ralph Nader ended the removable rear window..
Old Mar 17, 2007 | 02:43 PM
Shark Racer's Avatar
Shark Racer
My Avalanche had a removable rear window - as do all avalanches.
Old Mar 17, 2007 | 03:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Pretty sure you heard wrong.
Old Mar 17, 2007 | 06:26 PM
72LS1Vette's Avatar
72LS1Vette
The bean counters saved a few $ by eliminating the frame, latches and tray. Noise? - not much more than what you would hear with the glass in place. Turbulence? - I didn't go much over 50 last summer during the shakedown runs of the 72 but there wasn't any objectionable or even really noticeable turbulence with the tops off and the window out.
Rick B.
Old Mar 17, 2007 | 06:32 PM
carl a's Avatar
carl a
i know he was responsible for the blower motor always running(low is it ,,no off position) to keep positive air pressure/venting /no carbon menoxide
To Removable Rear Window
