Heat Riser Valve Shaft Hole
Old Mar 16, 2007 | 05:56 PM
79vetter's Avatar
79vetter
Default Heat Riser Valve Shaft Hole
I gutted my riser valve and am looking for suggestions on what to fill the hole is where the shaft used to be.
thanks
Old Mar 16, 2007 | 05:58 PM
chris73cpe's Avatar
chris73cpe
you could just tap it and put a machine screw in there
Old Mar 17, 2007 | 01:31 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
I think they offer A Spacer the same everything just no heat riser Why
did you take it off ? Mine is still on looks new no cats though A guy told me it just heats up the cats quicker? I Have no Idea.
Old Mar 17, 2007 | 02:02 PM
Gordonm's Avatar
Gordonm
Here is the spacer from Zip. It just goes in and is a spacer for the heat riser. The job of the heat riser valve is to heat up the intake manifold on cold mornings so the car runs better. It does nothing for the cats as they are after the valve.
http://www.zip-products.com/Zip/dept...37138F5155422F
To Heat Riser Valve Shaft Hole
