Wide 5 wheels...
Old Mar 16, 2007 | 06:03 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Default Wide 5 wheels...
Can I run these back wards? I take it I also need a spacer to clear the adapters also?
Old Mar 16, 2007 | 06:09 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Backwards? Flipped inside-out? That depends on the wheel and how it's built. You're not putting these on the Vette are you?
Old Mar 16, 2007 | 06:18 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
They would be real racing wheels.(the brand)
Yeah I am. I will be able to get each wheel down to about 10-11 pounds each.
This would make my tire/wheel combo come in weighing a very light 29-30 pounds.
Old Mar 16, 2007 | 06:36 PM
Twin_Turbo's Avatar
Twin_Turbo
Where are you going to find wide 5 hubs that will fit your spindles? or are you planning on running adapters which would defeat the whole wide 5 purpose
Old Mar 16, 2007 | 07:01 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Adapters
Old Mar 16, 2007 | 07:38 PM
norvalwilhelm's Avatar
norvalwilhelm
Coleman racing has complete listings on those wheels.While they are very light they only come in 15 inch and you need center adapter plates. It is just a plate drilled for the wide wheel studs and another set of holes for the stock 5 on 4 3/4
Old Mar 16, 2007 | 07:41 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Yep
I may just have to stick to the rally wheels
It's going to cost to much if the wheels I'm looking at aren't exchangeable. (they are brand new)
To Wide 5 wheels...
