75 vette
Old Mar 17, 2007 | 02:08 PM
Lon Wayne's Avatar
Lon Wayne
Default 75 vette
Is it hard to change out the rear seals in the rear end mine has one leaking from the half shaft area down on to my Exhaust I ordered both seals but dont know how to Install them .I put in A radiator so anything else is possible .Not the rear end cover. but where the H /S Are.
Old Mar 17, 2007 | 05:56 PM
Durango_Boy's Avatar
Durango_Boy
I think:
Repeat...
I think:
Unbolt and remove the half shafts.
Remove rear end cover.
Remove yoke clips and remove yokes.
Use a seal puller to remove old seals.
Tap in new seals.
Check yokes for wear and reinstall yokes and clips.
Replace cover with new gasket and new fluid.
Install and bolt in half shaft.
Sound right everyone or did I forget a step?
Old Mar 17, 2007 | 06:02 PM
redvetracr's Avatar
redvetracr
Originally Posted by Durango_boy
I think:
Repeat...
I think:
Tap in new seals.
yea, you sort of forgot to drop the differential...it only makes the job a little easier.......
...redvetracr
Old Mar 17, 2007 | 06:03 PM
Durango_Boy
...redvetracr
Yeah, I did not mention that but that part kind of has to happen to get the cover off.
Old Mar 17, 2007 | 06:04 PM
redvetracr's Avatar
redvetracr
it is a "step"...NO??
Old Mar 17, 2007 | 06:05 PM
Durango_Boy
Oh I was agreeing...I forgot it because I didn't differentiate between the two in my head.
Old Mar 18, 2007 | 10:02 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
thanks guys you guy are da shi/';[.
Old Mar 18, 2007 | 10:43 AM
Durango_Boy
No problem...let us know how it goes.
To 75 vette
