Stripped threads on intake
Old Mar 18, 2007 | 10:39 PM
JustinD's Avatar
JustinD
Default Stripped threads on intake
I striped out the threads on my water neck. I know there are some sort of thread inserts but I'm not sure what they are called. Would that work? Or am I going to be buying a new manifold soon?
Old Mar 18, 2007 | 10:51 PM
Durango_Boy's Avatar
Durango_Boy
They are called Heli-Coils. Most local parts stores will carry most sizes of them.
It would almost be better to take the manifold to a local machine shop, or do the work yourself, and drill and tap a size larger. Enlarge the holes in the neck, and bolt back down.
CA-Legal-Vette's Avatar
CA-Legal-Vette
Helicoil is the brand name. Pretty easy to use, especially in aluminum. Buy the kit and it comes with the tap and tool. Drill out the old hole, rethread and insert the Helicoil. Good as new.
Old Mar 18, 2007 | 10:54 PM
JustinD's Avatar
JustinD
I'll look for the Heli coils next time I run to the parts store. Thanks for the help.
Old Mar 18, 2007 | 10:56 PM
JustinD's Avatar
JustinD
What size are the water neck bolts? So that I know what kit to buy. Is it 3/8-16?
Old Mar 18, 2007 | 11:02 PM
682XLR8's Avatar
682XLR8
Yes, 3/8-16 UNC
aussiejohn's Avatar
aussiejohn
Default bolt size
Justin,
The bolts are 3/8" UNC about an inch and a quarter long standard, but just take your old ones to the shop and get two 7/16" the same length and a Helicoil kit to suit that size. Don't forget to enlarge the holes in the water neck accordingly. If you're regularly pulling your water neck off, you should think about putting in some studs and Locktiting them in and use nuts to secure the neck.
Regards from Down Under
aussiejohn
Old Mar 18, 2007 | 11:04 PM
Durango_Boy
aussiejohn
I like that stud idea.
Old Mar 18, 2007 | 11:22 PM
aussiejohn's Avatar
aussiejohn
Default .........."and that's not all........"
Thanks, D-boy, and here is another little trick if you pull the water neck off often. That is to machine an O-ring groove in the water neck (or manifold, but the neck is easier) so you never have to "glue" a gasket on (to ensure a leak-free fit) and the resultant scraping off when you open it up. Just clean the O-ring and re-fit it.
aussiejohn
Old Mar 18, 2007 | 11:28 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
It's 3/8" x 16, very common size.... the set is $19.98 at AdvancedAuto, just bought a set two days ago
They recommend a very uncommon drill size for the 3/8 insert, in aluminum you can drill 3/8" which is 9.5mm. It works fine, actually pefect..... the drill size that they recommend is about 9,8mm (.012" larger) - if drilling in steel I'd use a 9.8mm drill bit, for aluminum (softer) the 3/8" is perfect
Old Mar 18, 2007 | 11:30 PM
JustinD's Avatar
JustinD
Ok, my Intake is alum. So I'll use a 3/8 then.
Old Mar 18, 2007 | 11:46 PM
Bob3700's Avatar
Bob3700
Do yourself a favor and take the thermostat housing and drawfile the bottom of the unit to make sure it is flat. That way, once you reinstall everything, the gasket will have a better chance of sealing. Plus, the housing bolts were probably over tightened in order to keep fluid from leaking. Just a guess there.
Bob
Old Mar 19, 2007 | 07:58 AM
JustinD's Avatar
JustinD
I was torquing them to the specs said in the intake intructions and one of the bolts stripped. This was when I first put it in. I might just buy a new housing while I'm at it.
Old Mar 19, 2007 | 08:09 AM
Durango_Boy
aussiejohn
Also great info. I buy and install O-ring water necks on all my Mopar motors...I wish they were as easy to find for GM.
Old Mar 19, 2007 | 09:01 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
You can get the chrome version at any AdvancedAuto or AutoZone. They usually have the straight water neck on the shelf, you'll have to order the one that's angled to the driver side - takes less than a day.
I just bought one of their MrGasket chrome and O-ring necks, less than $10
Old Mar 19, 2007 | 10:24 AM
rjken1969's Avatar
rjken1969
I have to do this same procedure on my aluminum intake. Hopefully it's as easy as it sounds.
Old Mar 19, 2007 | 11:10 AM
rcread's Avatar
rcread
I've used this to repair the water neck threads. It's held for the last two years.
To Stripped threads on intake
Old Mar 19, 2007 | 11:27 AM
noonie's Avatar
noonie
Aluminum does not lend itself to repetitive use.
VW has put helicoils in their production engines for years to prevent this from happening. Studs as others have suggested is a good solution too.
Old Mar 19, 2007 | 11:57 AM
Wrencher's Avatar
Wrencher
When I built large bore high compression VW's, we used these on the cases for the head/barrel studs:
http://www.ondrives.com/products.asp?recnumber=437
Never had one fail.
Hans
Old Mar 19, 2007 | 12:01 PM
Durango_Boy
Never had one fail.
Hans
That's a cool site to have on link, thanks.
