Got my S/S lines and S/S & O-ringed Calipers from VB&P Saturday. They looked amazing. S/S lines installed very well minus the RR, which was a pain b/c I couldn't get the original line out of the recess. But everything else went well until I got to the Calipers. They wont bolt down without pinching the rotor. I compared them to the originals and the new ones taper down towards the rotor and the originals go straight down or slightly taper away from the rotor. Also the new calipers have tabs on them where it meets the rotor. My questions are concerning my idiocy. Am I doing something wrong here? Am I suppose to grind the tabs off? Has anybody else run into this?
Hopefully I'm just dumb and forgot something. We'll see. Hopefully Pattie will get back to me about them and help me out.
The bleeder valves were the correct numbers on all calipers in each place. Will the rear rotors work with the front calipers? Just wondering if a) the rear rotors are on the front and front on the rear. or b) The guy who did my brakes before used just front rotors all around. I'll check next time I go to work on it.
Thanks,
Josh
This will not work at all. This is probably part of your problem. Replace the rear rotors with correct rear rotors. Wow...that's very Bubba, I hope he wasn't a friend of yours.
I'll have to check those rotors. They are not riveted anymore, but they are still locked onto the hub pretty tight. Hopefully they weren't welded on. Is there a possibility that if I got the rotors off that I could machine the inside of the "hat" to make it thinner. I think that would work. It was only hitting on the outside part of the rotor. This kind of thing always seem to happen when I work on this car.
True, Probably needs it anyway. I didn't get to measure them to check thickness, but might as well assume they are crap. Like always, your on top of things, man.... er....boy.
