Rearend Question
Old Mar 19, 2007 | 10:49 AM
1B.DZ's Avatar
1B.DZ
Default Rearend Question
While I was doing my brakes I noticed excessive movement in my RR hub. I could rotate the rotor(when attached) a good 15 to 20 degrees. The Halfshafts turned ony slightly. Could the U-joints be going out? What else would contribute to this problem?
TIA,
Josh
Old Mar 19, 2007 | 02:11 PM
427-390's Avatar
427-390
Bearings?
Old Mar 19, 2007 | 02:25 PM
GaryS's Avatar
GaryS
TIA,
Josh
Normal. Since the diameter of the rotor is many times larger than that of the hafl-shaft, a big movement in the rotor will give a small rotation in the half shaft. In addition, your half shaft is bolted to the rotating wheel assembly. I can't imagine any way that you could get a slippage between the half shaft and the rotor!
U joints going south would be grinding and/or binding during movement.
Gary
To Rearend Question
