I need to replace the wiper switch on my 1981.
First, I must remove the instrument cluster. But, I pull out all the screws around the speedo/tach "Window", and only the plastic window comes out. The cluster itself doesn't budge.
Did you disconnect the speedo cable? It clips into the back of the gauge cluster at the speedo. The cable is very short and can hold the cluster in place.
I am just beginning to replace the interior on my 81 afgter pulling everything out to restore it. The Speedo Cluster had me stumped for a little while - i had trouble getting my big mits behind the cluster to pull the cable. BTW - got the new Dash pad in over the weekend, will begin on the gauge clusters this week.
when i yanked mine last summer it was actually stuck
in place i can only assume from heat, it had stuck itself
to the vinyl of the dash and took some prodding to remove.
also dont forget the main harness that plugs in to the back
of it, if i remember right there is just enough room to pull it
to the drivers door, sneak your hand in to undo harness
which will give you a little more wiggle room so you can
undo the speedo cable.
What am I missing?
There are two more screws underneath the dash pad,first you have to remove the panel which holds the headlight over ride switch.You will see two bolts which hold the steering rack up, either side of these bolts, you will find two more bolts[10mm i think] remove these and it releases the cluster.
Thanks, Windup. I think that this is the tip I was looking for.
i have had to do this more times than i care to remember. if you need to fully remove the gauge cluster, you'll have to unbolt the steering column and let it hang down. this is a real beotch to get out of there. even after you get the cable unclipped, you will probably have to put pressure down on the steering column to slide it over the column.
have fun with this one.
I have been putting my 81 back together and just put the Speedo and Tach in. I unbolted (two bolts) on the steering Column but it would not drop - i was able to force is down a half inch or so - just enough to slide the speed over it and into place. Is there something I missed to get more room? Radio and Center Cluster tonight.
Your finishing up the worst of it. Fitting a new dash was the worst part for me.
I had two problems - the first was getting both top clips in the other was getting those two screws in under the Speedo and Tach bezel. my old body did not like being a pretzel.
